It is currently Tue Jan 17, 2017 1:50 am
Post new topic  Reply to topic  [ 12 posts ]
 Post subject: Through-axle rigid forks
PostPosted: Fri May 31, 2013 9:02 pm
Anyone know of any other than the Niner RDO (frantically expensive) and the Salsa Cromoto Grande Maxle (heavy)?
PostPosted: Sat Jun 01, 2013 8:10 am
http://whiskyparts.co/catalog/forks
PostPosted: Sat Jun 01, 2013 10:18 am
Beware - it's not a fork for you if you weight more than 350 lbs :-D
My blog
PostPosted: Sat Jun 01, 2013 10:26 am
Not sure that's going to be cheaper than the Niner fork, either...
PostPosted: Sun Jun 02, 2013 2:33 pm
I have a cyclist friend who weights close to that and he rides a lot more than many on this forum.
PostPosted: Sun Jun 02, 2013 8:40 pm
I had hoped one of the manufacturers who make rigid forks (eg. White Bros, Shimano disguised as Pro) would have looked at this, as there is a demand.
Brant - are you reading this?
PostPosted: Tue Jun 04, 2013 2:54 pm
Are 'rigid' forks that flexible they would benefit from a through axle or is it just so you can use the same wheels?
PostPosted: Tue Jun 04, 2013 9:03 pm
Partly to allow same wheels (though eg. Hopes this isn't a problem as it's just a case of changing end caps), and partly to assuage worries about wheel ejection.
PostPosted: Sun Jun 16, 2013 3:06 am
+1 interested in the offerings. like good road disc forks, still hard to find.
PostPosted: Sun Jun 16, 2013 10:36 am
A correctly fitted wheel doesn't eject, full stop!
PostPosted: Sun Aug 04, 2013 9:11 pm
Looks like Salsa are about to launch one for 2014, details a bit lacking at this stage.
PostPosted: Sun Aug 04, 2013 9:30 pm
I used to have a Ritchey Logic tube fork when I bought a KHS Montana Team that was flexible enough to give some suspension----would these carbon forks give that type of compliance?
There are no new unread posts for this topic. Attachment(s) Niner RDO rigid forks. (Bolt through axel) UK
Steve_W
Sun Oct 23, 2016 6:30 pm
Steve_W View the latest post
There are no new unread posts for this topic. Attachment(s) Cannondale Rigid Fork
in MTB
FlatlandBicycles
Sun Jul 03, 2016 11:55 am
stoney View the latest post
There are no new unread posts for this topic. cannondale lefty rigid fork ?
in MTB
mikemon
Sun Oct 30, 2016 6:08 pm
TheKaiser View the latest post
There are no new unread posts for this topic. EE brake + Campagnolo lever = mush. Rigid housing the fix?
RedRacer
11
766
Thu Apr 14, 2016 1:28 am
bikerjulio View the latest post
There are no new unread posts for this topic. Thru Axle needed
in Wanted
SpeedyChix
Mon Nov 07, 2016 3:46 pm
SpeedyChix View the latest post
Users browsing this forum: No registered users and 6 guests
