It is currently Sat Apr 29, 2017 10:55 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Mon May 20, 2013 1:38 pm
Hi all, have got a problem with my Pro II hubs in that i'm having to frequently replace the bearings due to them seizing up, the front hub is especially bad and i'm changing bearings on it every 2-3 months.
I'm trying every brand of bearing under the sun from £1.50 ebay bearings all the way up to £12.00 FAG/SKF bearings... SKF/FAG do last longer but only by a couple of months at most. Every time I put new bearings in I make sure there is sufficient grease in them.
When a bearing seizes and take of the rubber seal inside there is still grease but its rusty/dirt coloured and the bearings wont move... its therefore a sealing problem, water/dirt is getting past the seals during rides- anyone else having this problem or got some suggestions to add an additional seal layer?
Conditions in my area generally tend to be wet, ground is predominantly chalk with some clay... after muddy rides the bike does get hosed down, not pressure washed, I tend to not spray around the hubs and clean them off by hand with a sponge or such like.
PostPosted: Mon May 20, 2013 6:38 pm
Sounds to me like your seals are damaged.
For certain parts stiffer is more important than lighter.
PostPosted: Mon May 20, 2013 9:37 pm
Are you using all weather bearings with double seals? The hope bearing design has a contact shield as part of the hub assembly which is the 1st line of defence.
The bearing itself also has its own seal which in its own rights should manage to deal with a lot of crud & debris trying to make its way to the bearings.
What sort of distances are you doing before cleaning? Are the bearings getting pressed in without damage caused to them.. Even the old hope ultralight used to give about 3k-5k usage before getting a little worse for wear, which would for most ppl be more than the use you are talking about.
PostPosted: Tue May 21, 2013 7:27 am
First mistake! Once the seals are snapped into place its almost impossible to remove them without nicking the sealing lip, instant leakage path. If you buy a decent bearing, they should have enough grease in out of the packet.
Are you fitting them with the right tools? If you fit them with the wrong tools its possible to move the races in relationship to each other, and damage the seal (plus the brinnelling of the races!). You can also put them in skewed/off axis, this either accelerates wear or can ovalise the bearing seat (game over for the hub, every bearing you fit from here on in will wear prematurely.)
Also, are your axles straight?
It's not necessarily a sealing issue either, tiny bits of ground up bearing will also leave the bearing gritty, brown and not turning very well.
(FWIW, i'm still on original bearings on some Pro2s which i've done three years on. I usually get 2-3 years out of a set of hope bearings)
PostPosted: Tue May 21, 2013 9:24 am
KaTec off ebay, super reliable, already filled with grease (not a 20-25% part fill) so you don't have to mash the seal by fiddling.
No jet wash involved I trust?
PostPosted: Tue May 21, 2013 10:50 am
Thanks for the replies... no i'm not using a jet wash to clean the bike, yes i'm using double seal bearings and have been using the proper tools, initially Hopes own hub tool kit, http://www.ukbikestore.co.uk/product/38/httpro2/hope-pro-2-hub-tool-kit-complete.html + the nylon wheel and then an actual bearing press, seized bearings are gently knocked out with an expanding bearing removal drift... I don't think I've ovalised the bearing seat and would say the axles are straight, but how should I double check that?
Yes I've taken the bearing seals off to inspect what grease is inside but not on the SKF/FAG bearings, and those only lasted an extra couple months at most.
Its the front hub that's the real problem, last year I was getting about 250-450mi out of each set of bearings.... I've replaced the rubber seal that sits between the QR axle cap and the bearing, plus I've replaced the QR axle cap all to no effect.
This isn't my first set of wheels with Pro II's, the last set I had were bombproof and I never touched the bearings once... they where the reason for going with Pro IIs a second time round.
Its either a hub that's out of tolerance or a sealing problem... cant do much about an out of tolerance hub but what can I do extra on the sealing side, any suggestions?
PostPosted: Tue May 21, 2013 2:58 pm
Next set of bearings that get pressed in: put a good layer of phil wood grease in between the bearing seals and hub endcap. Every couple of weeks I would pull the endcaps off and see how that layer of grease is holding up, and if necessary, clean and replace it.
As for having bores that aren't aligned, etc: anything of that nature you can typically feel when new bearings are installed. Misalignment will cause binding of varying severity.
Also, being careful, its definitely possible to not damage the bearing seals upon removal and reinstallation. I would imagine that isn't the problem. If extra grease around the seals isn't helping prevent contamination, I would recommend going to a marine grade grease (phil wood is expensive, repackaged marine grade grease).
PostPosted: Tue May 21, 2013 4:27 pm
Sealing wise, smear red rubber grease (waterproof marine) on the outside of the bearings, you can get it off ebay.
Not familair with hope, how do you preload the bearings?
I'd still try KaTec, Kai is a nut but knows his bearings.
PostPosted: Wed May 22, 2013 4:09 am
Why not contact hope and see what they say? Could be out of tolerance on the machining. Escapes of suspect parts are always a possibility in manufacturing.
http://www.hackracer.com/
PostPosted: Sun May 26, 2013 9:02 pm
+1. Hope's customer support is meant to be excellent so it can't do any harm to ask them.
PostPosted: Sat Jun 01, 2013 5:20 pm
:noidea: Very strange, I've got at least 1000 miles on my Hope 2 original bearings with no issues nor play (they are perfect..). Hub sealing seems to be good though. 9mm skewers. Maybe water gets in through your skewer/bolt holes? Do you ride in deep mud or something? I also recommend packing your newly installed bearings in grease (packing the hubs, not new bearings internally)
I even use a pressure washer once in a while, but try not to shoot the bearing areas.
There are no new unread posts for this topic. hope 20five-sp24
Carlin
Mon Oct 10, 2016 5:03 pm
StradaJon View the latest post
There are no new unread posts for this topic. hope rear hub weight
simoncx
Tue Feb 28, 2017 3:07 pm
simoncx View the latest post
There are no new unread posts for this topic. PC8 issues..
ParisCarbon
Sat May 07, 2016 10:03 pm
ParisCarbon View the latest post
There are no new unread posts for this topic. Hope Mono RS 80mm wheels - $450
AttacknowAttackoften
Sun Jan 29, 2017 9:07 pm
AttacknowAttackoften View the latest post
There are no new unread posts for this topic. Powertap Issues
greerso2004
Sun Jan 22, 2017 3:22 pm
greerso2004 View the latest post
Users browsing this forum: No registered users and 10 guests
