It is currently Mon Feb 20, 2017 2:39 pm
Post new topic  Reply to topic  [ 234 posts ]  Go to page Previous 15 6 7 8 916 Next
PostPosted: Sat Jan 04, 2014 7:33 am
How is the wear rate compared to shimano equivalent cassette cogs?
Experimental Prototype
PostPosted: Wed Jan 08, 2014 6:33 pm
JensW wrote:
Will the 40T work with 11-34? Considering that the different between 34 and 40 is the same as 36 to 42
Hi,
It will only work with 11-36 as it's been designed that way. 11-34 cassette is different if i can say so from the perspective of dimensions of the last spider. So AB sprocket would not have place to sit against the 34T sprocket on cassette. So it will not work.
Matthiass,
Well it's a bit difficult to say.
In "regular use", providing you have optimized your chainline correctly it will last you as long as cassette. This is because 40T won't be used as much as let say 17/20T cassette sprocket.
Chainline optimization is a key for having one drivertian for long time. Please always remember that, as improper chainline will wear you chainring, chain and cassette.
To set up proper chainline to your preferences, make a note what gears on the back you use most and aim to have a chain "straight" on the sprocket you use most of the time. Everyone is different, so each of us should have different chainline according to ones riding style/preferences.
Some of you will use bottom of cassette most of the time, and some only last few bigger sprockets..
Remember also, if you change front ring to bigger/smaller you will start using different sprockets on the back straight away. so with such a change, you need to optimize your chainline again! this is very important and most people forget about it.
http://www.absoluteblack.cc
http://www.facebook.com/absoluteblack.cc
http://www.keywin.cc
PostPosted: Sat Jan 11, 2014 9:54 am
tehan wrote:
Hi,
but would´t be good to design it to work with a 34? or to work with both. but it is maby not possible?
PostPosted: Wed Jan 15, 2014 11:57 pm
Any plans on making 32 or 34T chainrings for the S-Works cranks?
Tarmac SL2
Epic 2009
PostPosted: Sun Jan 19, 2014 1:11 am
yes:) we will have them before the season starts (March hopefully)
PostPosted: Mon Jan 20, 2014 8:28 pm
Oww I will be on the look-out and post it on our 1x11 ownersgroup facebook page.
Thanks
Tarmac SL2
Epic 2009
PostPosted: Wed Jan 22, 2014 8:20 pm
tehan wrote:
already designed and ready to manufacture in Jan:)!
So soon you will see them.
Follow mt Fb page to see when exactly. (link below)
Marcin
Are they done yet?
PostPosted: Wed Jan 22, 2014 11:48 pm
KMC issue with our chainrings RESOLVED!
So this is a day we have been waiting for! Most of you know we did not recommend KMC chains due to too big chain rollers.
After speaking with KMC few months back about the issue, we got today few samples of new chains directly from HQ which are going to be put to the test by us and few bike mags.
What that means for you? It means in few months all KMC chains available on the market will be compatible with our chainrings:)
Happy Thursday everyone.
We really appreciate KMC help on that issue. This does not happen everyday where such a big company like KMC is willing to help smaller company like us and their fans to overcome the problem.
Soon we may offer KMC chains on our web as well:) any propositions what would you like to see first?
PostPosted: Wed Jan 22, 2014 11:50 pm
Marcin
Are they done yet?
we start making them in few days. be patient as it's worth!
PostPosted: Thu Jan 23, 2014 5:48 am
Couldn't find any information on 120mm BCD on your website or in this thread. Do you have any plans on making such a chainring? I don't know how many runs on 2x10 80/120mm BCD, but it sure would be great to run a 1x10 setup. No one really offers a chainring for this purpose.
Thanks!
PostPosted: Fri Jan 24, 2014 2:02 am
Yes we will:)
Not for 120 but 80BCD - the granny position of that crank.
120BCD requires minimum 36T ring and these days no one use such ring as 1X solution almost.
So to give you smaller ring we need to go down to 80BCD. This is actually better for all as it provides improved chainline for 1X.
Only drawback is it will be available only in 28 and 30T. 32T in many frames may not fit due to collision with chainstay. Unfortunately these days most modern frames have press fit BB and there is not much one can do to move crank 2.5mm out to accommodate bigger ring.
We will provide 120bcd bashring to cover the tabs.
PostPosted: Sat Jan 25, 2014 1:39 pm
Hi Marcin,
I might have missed it but is there any availability on Hollowgram direct mount narrow/wide rings?
Thanks!
PostPosted: Sun Jan 26, 2014 6:12 pm
Shop Wrench
Tehan, my apologies if this has been covered but are the sram direct mount narrow wide chainrings available soon?
PostPosted: Wed Jan 29, 2014 6:42 pm
Hello, when will you start making the spiderless chainring for Sram cranks with XX1 style teeth?
PostPosted: Wed Jan 29, 2014 9:32 pm
Sram narrow/wide spiderless is in production in few days!:)
Hollowgram will follow after that.
There are no new unread posts for this topic. Carbon ti rings versus praxis rings
coppercook62
7
887
Wed Apr 20, 2016 6:17 am
KCookie View the latest post
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
674
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
There are no new unread posts for this topic. Alternative for TrainerRoad?
in Training
TonyM
Wed Nov 02, 2016 3:48 am
kkibbler View the latest post
There are no new unread posts for this topic. Alternative to 28MM GP4000Sii
Ltoddokc
Thu Nov 03, 2016 2:17 pm
Roel W View the latest post
There are no new unread posts for this topic. 3M FastTack 8031 Alternative
in Everything wheels
rgamble
12
515
Wed Jan 11, 2017 4:22 am
Nefarious86 View the latest post
Users browsing this forum: No registered users and 5 guests
