It is currently Sat Jun 24, 2017 8:28 pm
Post new topic  Reply to topic  [ 234 posts ]  Go to page Previous 1 2 3 4 516 Next
PostPosted: Sat May 25, 2013 9:02 am
An uneven numbers of teeth won't work if the chainrings are XX1-style....
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Sat May 25, 2013 3:47 pm
that is correct - only even numbers.
Are you thinking about CX rings? They sound really small.
I plan to do 130/40T & 42T and 110/38T in first instance. Let me know if you use something different.
http://www.absoluteblack.cc
http://www.facebook.com/absoluteblack.cc
http://www.keywin.cc
PostPosted: Sat May 25, 2013 8:33 pm
This is to show how good retention this chainring has. It's all about the tooth shape which can keep the chain in place. Only 5 links is enough to hold onto absoluteBLACK chainring!! Regular chainrings require at least double that.
Try to do it with yours and see result.
PostPosted: Sun May 26, 2013 1:20 am
I use a 5 bolt 110bcd crankset on my mtb - was hoping for a 34.
I'll be purchasing a 130bcd 42 for the cross bike.
Grover's Grumblings
Grover's Garage
PostPosted: Sun May 26, 2013 4:56 pm
hmm, sorry but no plans for such small ones for 110bcd. I still have few cranks like that in my garage but this BCD for mtb is officially dead so i can't make just one.
But i will surely do ones for CX. stay tuned.
and just to want to add two more pictures as someone in Germany actually made a photo that he can do that with 6 links on fsa single ring (but admitted that with huge effort).
My rings hold it even with 4. You just physically can't get lower! This is an ultimate proof how tight tolerances there are in the ring.
PostPosted: Mon May 27, 2013 5:43 am
Looking at your photos I'm having trouble seeing a difference between every-other-tooth. I know you said that your newer rings aren't narrow-wide like the XX1 rings... so is there _any_ difference between every-other tooth? (If not then there'd be no reason you couldn't do odd numbers of teeth, not that such a thing is really necessary)
Rise Bikes
Wilier Cento1SR Disc
PostPosted: Tue May 28, 2013 8:08 pm
tooths on these ones are identical. So could do odd numbers. But since i share tooth design with my 104BCD rings it's easier for me to stick with even numbers.
Besides demand for odd numbers is really low. People are so used to riding on 32,34, 36 that they look no further as on every forum you can see such numbers. So people just buy what they read:)
PostPosted: Sun Jun 02, 2013 12:31 pm
Hi,
I am pleased to announce that 104BCD rings are now available to pre-order on the website.
I will do my best to deliver them like advised on the website:
http://absoluteblack.cc/xx1-style-shimano.html
PostPosted: Sun Jun 02, 2013 4:32 pm
I would like to get 38t 104 BCD :thumbup:
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Mon Jun 03, 2013 1:29 am
1 38T for me too! :wink:
PostPosted: Mon Jun 03, 2013 8:07 am
Any plans to make 94mm BCD rings for compact MTB (94/58) cranks?
PostPosted: Mon Jun 03, 2013 9:45 pm
38 is in the works:)
94BCD - i am afraid that not many people using it anymore so i can't make just few in the process i am using.
I have few singlespeed chainrings left 33T in 94x4holes pattern, but these would require a chainkeeper.
PostPosted: Mon Jun 03, 2013 10:34 pm
Still no requests for a BB30 version?
PostPosted: Mon Jun 03, 2013 11:49 pm
hmm, i already wrote on my site that it works as i figured out where the problem was.
So you can potentially order one if you read that below and figure out what spacer you have. Most people wrote me that with longer spindle works great. With shorter also works ok, but some frames does not accept that...and this was the problem.
(*) BB30 users - There are two axle lengths in that system. One is 5mm longer than the other one. Longer spindle is usually mounted as OEM where you have BB shell of 73/83mm and wider in the frame. Shorter spindle is usually mounted to the frames with 68mm bb. Now, using absoluteBlack chainring with longer spindle creates ideal chainline of around 51mm (means, it works great). Using same ring with shorter spindle from the other hand pushes the ring inboard by 5mm making a chainline of 46mm. In some rare cases frame may not accept that. Also in such case you can't use the chainkeeper (if you would wish of course, as it's not needed). You could move bb spacers around to compensate for that, but it requires a bit of skills. It is easy to distinguish the two. Longer spindle has big 10mm spacer on drive hand side, where shorter spindle will have only 5mm spacer there. If your bb30 crank came with a bike you most likely have long spindle and our chainring will fit perfectly.
If you find that explanation difficult then write to me and i will try to help.
PostPosted: Tue Jun 04, 2013 5:15 am
Are this type of measurement valid?, My thought is the opposite to reduce the amount of chainsuck.
The chain should slip off the ring easiest possible way to maintain a long chainsuck free life.
That´s only me.
Experimental Prototype
There are no new unread posts for this topic. FC-9000 crank with 56-44 rings or just the rings
lactatehate
Tue Apr 18, 2017 3:13 am
FIJIGabe View the latest post
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
875
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
There are no new unread posts for this topic. Alternative for TrainerRoad?
in Training
TonyM
Wed Nov 02, 2016 3:48 am
kkibbler View the latest post
There are no new unread posts for this topic. any alternative GXP crankarms?
addictR1
Thu May 11, 2017 4:02 pm
addictR1 View the latest post
There are no new unread posts for this topic. Alternative to Selle SMP?
liam7020
9
581
Sat May 06, 2017 6:39 pm
Kjetil View the latest post
Users browsing this forum: batcave and 5 guests
