It is currently Mon May 22, 2017 8:33 pm
Post new topic  Reply to topic  [ 234 posts ]  Go to page Previous 18 9 10 11 1216 Next
PostPosted: Thu Jun 26, 2014 8:46 pm
stuka666 wrote:
Weight savings from replacing the xx1 ring for this one? (the new narrow wide)
Works better and the ring stays in the exact same place as the xx1?
It's all on the website.
It's online again:The Machinist
My CAAD10:http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=109014
PostPosted: Thu Jun 26, 2014 11:07 pm
Quote:
These chainrings save more than 150g over the regular spider and chainring combo. Reliable, extremely light, stiff and clean looking on the bike. Fear no more about loose chainring bolts or compatibility issues – go spiderless!
I'd like the real experience and photos, I read the website already.
PostPosted: Sun Jun 29, 2014 4:40 pm
@ tehan: is your e-mail address still "contact at absoluteblack.cc"? I have sent you two emails weeks apart without any response, hence my question.
Cheers!
PostPosted: Mon Jun 30, 2014 4:30 pm
yes, same.
Maybe it went to spam? Can you write me on Facebook what's your email so i will try to dig it?
http://www.absoluteblack.cc
http://www.facebook.com/absoluteblack.cc
http://www.keywin.cc
PostPosted: Mon Jun 30, 2014 4:34 pm
Done, thanks for your reply!
PostPosted: Mon Jun 30, 2014 9:29 pm
stuka666: Not 100% sure on the weightsaving but around 45g. Same place on GXP cranks. My 34t is working perfect, absolutely love it.
/jonas l
PostPosted: Tue Jul 01, 2014 8:25 am
Thanks for the answer, when the time comes for a new chain ring, will try one of these.
PostPosted: Thu Jul 03, 2014 2:09 pm
Anyone know where I can get a 34/36T 110BCD one from?
without having to spend a silly amount.
MTB Rider.
TORQ Performance.
#Science
PostPosted: Mon Jul 21, 2014 11:07 am
We know many of you have been waiting for that long time.
We will have soon Sram direct mount BB30 SHORT spindle version.
Our current offering has 6mm inward offset which fits nicely to GXP and long BB30 spindle cranks. But such ring could not clear chainstays for short spindled BB30.
So the new spiderless chainring is completely flat and will fit to Short BB30 cranks and Fatbike cranks.
How to distinguish short and long BB30? That is fairly easy.
Short BB30 spindle has 9mm spacer on the drive side. Where long version will have 15mm one.
PostPosted: Mon Jul 21, 2014 7:36 pm
Dropped my chain once last weekend, Absolute Black 34t chainring and XX1 drivetrain. Anyone know of a light but good chainguide for Shimano direct mount?
/jonas l
PostPosted: Tue Jul 22, 2014 8:48 pm
check your chain length first as this may be reason of that drop.
If you ride full sus then at full compression if you change gear quickly there is a chance to drop it. Also as countermeasure - if you ride a lot on smaller cogs on the back i would get bigger chainring, so you could ride more on the middle of the block on the rear. This will mean more chain wrap and greater tension on the rear mech cage. This is a very good workaround if you ride aggressively.
PostPosted: Wed Jul 23, 2014 10:20 pm
chain length is good, Trek Remedy fs. Maybe was something with the rear derailleur too, never happened before or after.
/jonas l
PostPosted: Fri Jul 25, 2014 2:00 am
so maybe then a small stick or something else got under the chain as this happens sometimes. I would not worry so much about one drop.
PostPosted: Mon Jul 28, 2014 9:03 pm
Tehan, are you still planning for an S-Works DM N/W 30T this summer?
Thanks
PostPosted: Wed Jul 30, 2014 8:07 pm
yes, in fact we already have designs. We need to just make it.
There are no new unread posts for this topic. FC-9000 crank with 56-44 rings or just the rings
lactatehate
Tue Apr 18, 2017 3:13 am
FIJIGabe View the latest post
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
834
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
There are no new unread posts for this topic. any alternative GXP crankarms?
addictR1
Thu May 11, 2017 4:02 pm
addictR1 View the latest post
There are no new unread posts for this topic. Tornova alternative
havana
7
482
Sun Apr 09, 2017 1:01 am
MisterMuncher View the latest post
There are no new unread posts for this topic. Alternative for TrainerRoad?
in Training
TonyM
Wed Nov 02, 2016 3:48 am
kkibbler View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Yahoo [Bot] and 2 guests
