It is currently Fri Jan 19, 2018 4:58 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
PostPosted: Sat May 18, 2013 5:50 pm
This may be a dumb question, but I was wondering if anyone has tried building up a set of 29er wheels with carbon tubular road rims since they are, to my understanding, approximately the same size. Farsports' rims and wheels have been getting good reviews over in the road forum and it looks like they do a 260g, 24mm-deep rim with up to 32 hole drilling that might work. Of course, it might be slightly too small for a 29er tire.
Andrew "Jersey" L
PostPosted: Sun May 19, 2013 3:06 pm
Road rims are generally not rated for disc brakes and also generally do not have enough spoke holes for a durable 29er wheel. In most cases you need at least 28 spokes and everything disc rated. Since there are few hubs and rims with 28 holes you will probably end up at 32.
For certain parts stiffer is more important than lighter.
PostPosted: Mon May 20, 2013 1:42 am
It looks like the one I mentioned above from Farsports can be 28 or 32 holes so that would not be a problem. As for being rated for disc brakes I'm not sure what you mean. To my understanding rims are usually more stressed out by rim brakes than from discs. As in, a rim with a rim brake track will usually be heavier than the same rim without because it will require more material not only for the track but on the inside ("bridge?") to withstand the force of being pinched by the caliper. Correct me if I'm wrong.
It seems like the only factor would be the outer diameter in this case.
Andrew "Jersey" L
PostPosted: Mon May 20, 2013 3:04 am
The spoke holes have to be stronger on disc wheels since all the braking force is transmitted through the spokes to the rim and tire. A non-disc rated rim will soon start to crack the spoke holes on the spokes that pull when you use the disc. Also, a rim with a brake track will generally weigh more than a disc rated rim so I don't see the advantage of this build.
 Post subject:
PostPosted: Mon May 20, 2013 3:51 am
This may be true in theory (I don't know that it is or isn't), but in practice folks like Velocity and Stans (and I am sure many others) offer disc builds with their road rims which to my knowledge have no additional material added to the spoke holes. It would probably be a good idea to use washers, but then that probably never hurts. And 28h is a pretty commonly available drilling for road rims ...
I believe Farsports offers disc builds of their CX rims? Or maybe I am confusing them with one of the others.
PostPosted: Mon May 20, 2013 5:26 am
the farsport 24/25mm wide "CX" rims might be worthy candidates, though they are significantly heavier than the 260g rims you're talking about.
interested to see how this goes...
PostPosted: Thu May 23, 2013 7:04 pm
Planet X do carbon cyclocross wheelsets with disc hubs. Price is pretty damn impressive also...
PostPosted: Fri May 24, 2013 6:33 am
Those are a good price and the weight is pretty good, too, but I'm looking for rims that are sub-300g or tubular wheels that are sub 1200g and far below the price bracket of Extralite and AX Lightness.
I guess it doesn't matter that much since a pair of tubular 29er tires weigh 200g more than their clincher counterparts and there are several reasonably priced 29er clincher wheelsets in the 1400g range. While I love Stan's bead hook I would like something stiffer than the Race Golds at the same weight; though I have not tried the that wheelset, I'm just going on reviews. Farsports' carbon 29er wheelset is advertised at 1410g but I'm leery of running them tubeless. Even though they are probably stiffer it's not worth the trouble dealing with burping tires if they don't have the tight interface with the bead. So I was thinking that a carbon tubular wheelset might fit the bill.
Those 260g rims that I mentioned are 20.5mm wide. Do you guys think that loosing 3.5mm of width (Enve tubulars are 24mm wide) would be a big deal? Maybe we can convince Farsports to make a 24mm-wide tubular rim that's a few grams heavier.
Andrew "Jersey" L
PostPosted: Mon May 27, 2013 9:16 am
Lofty goals, but I would be wary of using a big tyre with narrow rim, and run it at low pressure. The Glueing tubulars thread has lots of good info, including CX glueing practices.
In general I'd not worry too much about spoke holes tearing from disc usage, unless you're a beefcake. The (also negative) acceleration offroad seems to be limited by grip anyway. What might be a concern however, is that a single bottom-out on a 260g rim could be the end of your race. For hillclimbs and smooth XC courses such a set would be quite appealing, though.
PostPosted: Mon May 27, 2013 11:26 am
I'd love to have a set of 26mm tubular rims, like those on the DT Swiss 950Ts.
Are these companies listening?
PostPosted: Mon May 27, 2013 5:07 pm
AX Lightness claim the SRT CC 29er rims weigh 255 g each, and measure 28 (height) x 25.5 (width) mm. The ENVEs are not too far off, and probably a bit stiffer because of the incresed weight.
Maybe I missed something, but why not go for tubular rims by either AX Lightness or ENVE?
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Mon May 27, 2013 6:05 pm
Cost? :P
PostPosted: Tue May 28, 2013 8:54 am
So, looking at the DT Swiss 950t rims vs. the 23mm wide generic carbon offerings, it looks like they have more or less the same gluing surface, in terms of width available to support a tire. Anyone have experience with either, when it comes to mounting 50mm tubulars?
PostPosted: Fri Jun 21, 2013 8:18 am
I've built up AX-lightness tubular 29er rims with extralite hubs and CX/rays however these rims which produced 1090gr 29er wheels are totally different in profile to a road rim they're quite wide and feel far stiffer both radially and literally. My suggestion don't risk it use Innolite or AX or even FRM alloy
PostPosted: Fri Sep 27, 2013 10:18 am
Hi I am new member here. :D
Would like to discuss with you guys about those cheap china carbon tubulars.
My 29er wheel seems heavy, slow , sloggy ect. I am king of feeding up with it.. :x
Just thinking mtb tubulars would gain some advantages in ways of speed, weight and performance....
I have questions.
29er tubular tire options seems limited??
I can't find much vendor that offer wide 29er tubular rims, do you have recommendation?
:welcome: and idea?
There are no new unread posts for this topic. PRO 3 Spoke - Ultegra - Carbon Front Wheel -> Track or Road wheel ?
in Everything wheels
Tillquist
Fri Oct 06, 2017 6:18 am
F45 View the latest post
There are no new unread posts for this topic. Can I buy this tubular wheel and fix it?
Sm0421
Tue Sep 19, 2017 3:46 am
LouisN View the latest post
There are no new unread posts for this topic. best tubular spare, wide rimmed wheel
are
Sat Aug 05, 2017 8:34 am
willmac View the latest post
There are no new unread posts for this topic. tubular wheel thoughts: Easton EC90 SL vs. DT RC 38 Mon Chasseral
lasrever
Fri Jul 28, 2017 4:21 am
CycloTron View the latest post
There are no new unread posts for this topic. Powertap GS / Carbon tubular 40mm rim rear wheel
LouisN
Thu Dec 07, 2017 12:42 pm
Users browsing this forum: No registered users and 5 guests
