It is currently Mon Dec 18, 2017 9:40 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Tue May 14, 2013 2:07 am
Does anyone know where I can find an adaptor to fit an IS brake to a fork with a post mount?
Ridley Excalibur
Scott Spark LTD 8.15kg (retired)
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Tue May 14, 2013 10:12 am
Sort of.
Shimano used to do them to allow fitting IS Calliper to post mount for 180 mm disc.
The only other source is KCNC adapter. <-- linky
It comes in 3 flavours for: 160, 180 and 203 mm discs. Front IS calliper have shorter mounts than rear IS calliper which in theory means that you can run a 160 mm disc on a post mount fork using the front calliper.
but, and it is a big BUT there may be insufficent clearance so you may need to go to 180 mm disc - either fit rear calliper on front using 160 adapter or use front calliper with 180 adapter.
As an example, Shimano XTR m975 front IS calliper cannot run a 160 mm disc on a Fox post mount fork.
PostPosted: Wed Jun 05, 2013 10:10 pm
I received it and it didnt fit.
Ridley Excalibur
Giant NRS (Retired)
PostPosted: Thu Jun 06, 2013 4:01 pm
Received what and didn't fit what and why?
PostPosted: Mon Jul 08, 2013 1:13 am
Magura QM3 looks like this - but, you will need to run a 180mm rotor....
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
There are no new unread posts for this topic. Post mount Disc options
ParisCarbon
Fri Jun 16, 2017 9:45 pm
ooo View the latest post
There are no new unread posts for this topic. Found, can be deleted - Magura MT8 left/front brake
in Wanted
MrIzoard
Mon Dec 11, 2017 8:03 pm
MrIzoard View the latest post
There are no new unread posts for this topic. Campagnolo Post Mount Disc Work Around
morrisond
43
4246
Mon Dec 04, 2017 11:38 pm
geodandrew View the latest post
Users browsing this forum: No registered users and 5 guests
