chain droping from big ring
Getter
by Getter
If my order goes through this week, I should have it by Friday. I'll ride it this weekend.
Right now I'm using a 36T Truvativ ring. I ordered a Blackspire Super Pro. We'll see how it goes.
Getter
by Getter
The Blackspire ring was out of stock.
Based on a suggestion of the mechanic...I replaced the SRAM X7 FD with a Shimano XT. Well...I did two rides this weekend and my chain has not dropped. The shift to the big ring is much lighter and faster than the X7.
devinci
by devinci
I have tightened my front derailleur cable and I have not had any issue so far. It might need to take a bit more rough descent to confirm everything is OK. Sram or any 80-120 chainrings seems hard to find at good price online
Snabb
by Snabb
I have been having the same exact problem. It`s not the setup of the front derailleur. There is only so much you can do with the setup of the FD. I bought a new frontring which eliminated the problem... for like 10 rides, then it started to happening again. I tightened the spring in the RD but with no luck. Then I switched from SRAM chain to Shimano and now the problem is gone. I didn`t have this problem earlier either when I was running a KMC chain. Seems the SRAM chain is a bit stiff sideways which makes it drop the chain in certain gears.
I have a friend who had the same problem on SRAM Red and switched to shimano chain and, voilà!
I had to get of the bike several times in my last race so I know the feeling, maybe a clutch type RD will work also. Like the type 2 SRAM. If this problem comes back I will just order a new XTR group right away :beerchug:
Ride lots!
devinci
by devinci
thanks for your feedback snabb
the problem happens less frequently since I changed my chain and increased the FD cable tension. Though it seems to come back when the chain wears out slightly. I have ordered 2 sram chains... didnt know they could be problematic.
I too would change over to XTR but I love grip shifts and I would not mix match my sram SRM with shimano components :D
