Rear Derailleur M972 XTR Shadow vs M953 vs M952
adidavas
by adidavas
Rear Derailleur M972 XTR Shadow vs M953 vs M952 which is best in all conditions?
Liggero
by Liggero
why not 971?
Happy Trails !!!
tzeonn
by tzeonn
what shifters are u using? i'd pair 950s with 952 and 970 with 972/1. 953 is a rapid rise rear dee, so shifting will be reversed.
Liggero
by Liggero
I use grip shift with shimano front and rear ders., I like it much more than shimano shift levers, as i can shift several gears with a small movement. I like it much more than sram with gripshift, because as shimano has a shorter cable ration, the movement in the grip shift it's much smaller than with full sram.
Happy Trails !!!
adidavas
by adidavas
I have XT770 shifters. Why I asking, I have problems with M972 in sand, rain and dirty conditions
anicomp568
by anicomp568
There is no need to make a move back to 952. Change the cable housing, adjust the derailleur precisely and it must work fine.
Shut Up Legs! (Jens Voigt)
tzeonn
by tzeonn
what probs did u have with 972? shifting probs?
maybe a non-exposed rear dee like 960/952/953 could help in blocking out the mud?? hard to clean the embossed "xtr" on 972 too :D
thisisatest
by thisisatest
If your Der housing is not one uninterrupted piece, make sure you use housing end caps with o-ring seals. If the housing is not prelubed like Shimano sp41 and Jagwire L3/LEX, then lube the cable prior to insertion.
there is no reason why your current setup can't be made to be reasonably tolerant of sand and mud.
skyfire1202
by skyfire1202
Shorter caged derailleurs for ground clearance?
I used to have an M952 short-caged RD when I started racing and looking at how messy other people's long caged derailleur after muddy races got me sold with short-caged RDs and had all my MTBs installed with Dura-ace RDs on 2x9 setups. Now I want to try XX1 on two bikes and hope I didn't make the wrong decision.
