It is currently Tue Jan 24, 2017 2:57 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Sat May 11, 2013 6:08 am
I've been using the 610 gram racing ralph 2.25" performance line version and like them except they started leaking sealant around a seam in the sidewalls. it does take about a month for a serving of sealant to make its way out. these tires aren't "tubeless ready" so I guess thats why this is happening after about 5 months. the evolution line is TL ready but cost double the money. so anything around $40 that have similar weight and TL ready?
PostPosted: Sat May 11, 2013 6:20 pm
I just got 2 RR Evolution line 29 x 2.35. They were supposed to weigh 620 grams and they actually weighed 550 and 570. They sealed up fine (the 550 one had a pinhole that sealed immediately) and I bought mine on ebay for a landed cost of $54.50 each: http://www.ebay.com/itm/330905912494?ss ... 1439.l2649
For the few more bucks and the weight savings and performance gain, I would buy these in a heartbeat.
For certain parts stiffer is more important than lighter.
PostPosted: Sat May 11, 2013 6:22 pm
One other point of information. The compound on these is very soft and sticky and they might not last as long as the previous RR 2.4 with the 390 compound but they sure do stick.
PostPosted: Sun May 12, 2013 3:20 am
conti race kings do ok for the dollar. not as sticky as a racing ralph but at like half the price it's best not to complain. does the job on our local sandy hardpack, sandstone and leaves. not sure about real-world weights unfortunately...
PostPosted: Sun May 12, 2013 5:18 am
yourdaguy wrote:
I just got 2 RR Evolution line 29 x 2.35. They were supposed to weigh 620 grams and they actually weighed 550 and 570. They sealed up fine (the 550 one had a pinhole that sealed immediately) and I bought mine on ebay for a landed cost of $54.50 each: http://www.ebay.com/itm/330905912494?ss ... 1439.l2649" onclick="window.open(this.href);return false;
thanks for the link. I found the 2.25" from the same seller for sale. I've always thought the compound on my RR were soft, which I like for the front at least, so if the evo is softer, that could be trouble for the rear tread life.
since the tread in the rear is almost gone on my RR at almost 3000 miles, I was thinking of getting something with a harder compound. like maybe the maxxis ikon, but they don't say if its TL ready or not. my front tread is fine, could probably go another 3k miles. just need both tires to be TL ready so I don't go through sealant.
PostPosted: Sun May 12, 2013 5:28 am
The Ikon without the snakeskin is my favorite rear and the RR is my favorite front. The Ikons wear longer but they have a very thin sidewall. They will be fine, but when you first inflate them with sealant they might have several holes in the sidewall. Those holes will soon seal and they will be fine. Half my bikes are set up Ikon rear RR front.
PostPosted: Sun May 12, 2013 6:05 pm
how long have you had your ikons set up with stans?
PostPosted: Sun May 12, 2013 8:08 pm
Close to 2 months.
PostPosted: Sun May 12, 2013 8:26 pm
yourdaguy wrote:
Close to 2 months.
hm, was hoping you would say a year. I don't want to have the problem that I had with my RR. what other tires compare to ikon for compound and weight?
PostPosted: Sun May 12, 2013 9:05 pm
My favorite combo is RR 2.35 front and Ikon 2.2 rear. There are no other tires that I am aware of that are less than 600 grams actual and have this much traction and volume. The Ikons have several hundred rear miles and are holding up well. I actually think I would like the RR even better on the rear but like you, I think they would wear too fast. I would not worry too much about the TL ready aspect. That is probably why my Ikons had some pin holes when I first mounted them, but that is what sealant is for. On my rims after being run tubeless for over a month the Ikons end up at 2.2 and the 2.35 RR's end up at 2.3 which since I usually like a slightly larger front this aspect works out well also.
PostPosted: Sun May 12, 2013 9:11 pm
I have a good experience with Conti X-King. I do not know if they are labelled as tubeless ready, they were losing pressure for the first 2-3 days. Now after 700 km still without any problem.
Shut Up Legs! (Jens Voigt)
PostPosted: Fri May 17, 2013 4:42 am
any more recommendations? I looked closer at my tires where I see the wet line. its not so much a seam but a line of tiny cracks. I've taken the tire off and removed clumps of dried sealant in the past, never scrubbed the tire out though. maybe if I scrub it out the sealant will seal up these cracks?
PostPosted: Fri May 17, 2013 7:22 am
I have not familiarity with the performance line so I can't help.
PostPosted: Thu May 23, 2013 6:55 am
I'm running S-works Fastrak in the back and S-Works Ground Control up front, 2.1 I think.
There are no new unread posts for this topic. Tubeless tires, low psi - how does it hold air?
wheelsONfire
Thu Mar 17, 2016 1:15 am
wheelsONfire View the latest post
There are no new unread posts for this topic. Mavic SLR/R-SYS with tubeless tires
in Everything wheels
BugsBunny7788
Tue Aug 23, 2016 8:11 am
BugsBunny7788 View the latest post
There are no new unread posts for this topic. Tubeless tires, seating without air compressor
wheelsONfire
12
787
Thu May 12, 2016 5:51 pm
garlet View the latest post
There are no new unread posts for this topic. Maxxis Aspen tubeless (29er) tire release date?
in MTB
the_marsbar
Mon Sep 05, 2016 11:56 am
stoney View the latest post
There are no new unread posts for this topic. Help plz. Searching for skin wall /white tubeless tires
YoungjaeChoi
Tue Jan 17, 2017 7:50 pm
shimmeD View the latest post
Users browsing this forum: Yahoo [Bot] and 7 guests
