It is currently Sat Jan 20, 2018 2:19 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu May 09, 2013 5:51 pm
I have got a UniTi BB92 pressfit BB for my bike - it comes with a spacer. I have tried mounting it with the spacer but there seems to be some play.
Do any of you use spacers with your BB92 pressfit BB?
My blog
PostPosted: Thu May 09, 2013 6:20 pm
put other shims to eliminate play and don't care about others ....
ciao Mads :-)
http://eliflap.it/
PostPosted: Thu May 09, 2013 6:36 pm
Other shims and don't care about others? Andrea - how many spacers are that? 2?
My blog
PostPosted: Thu May 09, 2013 7:04 pm
sorry ...i red you post but my brain red crank not BB .....
try the "gold paper" , thin copper film
http://eliflap.it/
PostPosted: Fri May 10, 2013 1:48 pm
Got a standard bb92 from Sram that fits. Gonna have a talk with UniTi because the cup in the driveside was way to loose.
My blog
PostPosted: Sun May 19, 2013 12:25 pm
you have to use the 2,5mm spacer on the drive side, if your bottom bracket shell is 89,5mm wide.
You need an empty Excel Part List?
www.crazyeddie.de
PostPosted: Sun May 19, 2013 1:53 pm
Yes - used the spacer. I have located the problem to the cup in the driveside is too small. The Sram fits perfectly with no play but a bit heavier than the UniTi. I'm in contact with the shop so I hope for a good solution.
My blog
There are no new unread posts for this topic. Help installing DuraAce BB92-41 Bottom Bracket
apctjb
Fri Dec 08, 2017 4:23 pm
apctjb View the latest post
There are no new unread posts for this topic. Crank ideas for 2017 Scott Addict with BB92 PF
Johnny Rad
Tue Feb 14, 2017 5:42 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Vumaquad on a pressfit bbright
JLS
Sat Feb 04, 2017 8:27 pm
BMWCARMAN View the latest post
There are no new unread posts for this topic. Damaged surface of Campagnolo Ultra Torque PressFit Cups
3Pio
32
2085
Sun Oct 15, 2017 5:44 pm
winkybiker View the latest post
There are no new unread posts for this topic. Colnago C60 fork: are spacer under/ above the stem necessary?
TonyM
Mon May 22, 2017 3:17 pm
Calnago View the latest post
Users browsing this forum: No registered users and 10 guests
