It is currently Tue Jan 23, 2018 3:33 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Fri May 03, 2013 12:58 pm
Anyone know of a place I can buy only the red brake blocks used for bleeding avid brakes?
Thanks
Greg
TIME RXR
PostPosted: Fri May 03, 2013 2:30 pm
I think that the Avid bleed kits come with all the different Avid blocks. Otherwise just google or bing the appropriate model and the words bleed block. Which red block do you need? I might have it and not need it depending on your model.
For certain parts stiffer is more important than lighter.
PostPosted: Fri May 03, 2013 2:51 pm
I have a bleed kit already. I have misplaced the red blocks. No luck with google search for the blocks only....
I have the Elixer 5S model.
Thanks for any help
TIME RXR
PostPosted: Fri May 03, 2013 3:03 pm
Elixir and Jucy are the blocks I need so I can't help. I measured mine and it is exactly 10 mm thick so you can make your own.
PostPosted: Fri May 03, 2013 8:08 pm
Ok that does help. I used a wood shim for installing doors or windows cut down to fit.
Thanks tho
TIME RXR
PostPosted: Sat May 04, 2013 8:19 am
Bike shops would throw many of these in the bin daily. They often come with new bikes. Go into the LBS and they'll probably give you one.
PostPosted: Wed May 08, 2013 1:22 pm
No the pad spacers come in on bikes, not the bleed blocks.....
PostPosted: Wed May 08, 2013 7:49 pm
They're one and the same thing. Thin end is pad spacer, thick end is bleed block.
PostPosted: Wed May 08, 2013 10:16 pm
No bleed block have - well - bleed block written on them
http://www.bikegoo.co.uk/product.php/64 ... uicy_2008_
PostPosted: Thu May 09, 2013 2:21 am
Well Rookie, if you scrolled down to "People who purchased this also purchased..." you would see the Elixir Bleed Block has - well - pad spacer written on it....
:smartass: :popcorn:
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Thu May 09, 2013 2:22 am
The bleed blocks are 10 mm thick so that is all he needs.
PostPosted: Thu May 09, 2013 1:51 pm
Argh, won't fit a Juicy, thought they were the same block....
PostPosted: Thu May 09, 2013 2:27 pm
Jucy block is totally diff and has a notch on each side to allow for the part of the caliper pucks that snaps into the pads. A lot harder to make. To make matters worse, there are 2 types of Jucy blocks: grey and red. The grey are for fist gen Jucy and the red are for 2nd gen Jucy and they are different thicknesses. Also, Jucy does not have pad spreader end either.
There are no new unread posts for this topic. Attachment(s) Bleed screws in Shimano hydraulic levers
lovemyway
31
1380
Mon Jan 22, 2018 12:00 pm
DDX View the latest post
There are no new unread posts for this topic. Disc brake AND rim brake?
in Everything wheels
MiddMan
12
942
Sat Jul 15, 2017 2:52 pm
dmulligan View the latest post
There are no new unread posts for this topic. EE Brake Set up
piercebrew
15
1699
Wed Jul 26, 2017 5:42 am
beanbiken View the latest post
There are no new unread posts for this topic. Brake SQUEEL...HELP!
simplemind
14
797
Sun Dec 03, 2017 1:53 am
Lewn777 View the latest post
There are no new unread posts for this topic. Ultegra brake
Timmy269
Fri Oct 13, 2017 1:08 pm
Timmy269 View the latest post
Users browsing this forum: No registered users and 4 guests
