It is currently Tue Jan 16, 2018 2:25 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Apr 25, 2013 2:36 pm
Can a 10 speed crank run a 9 speed chain? The crank in qn is a m985 double with an xtr 9 speed chain. I also notice some protrudding links on the back of the big chain ring, anyone knows what this is for?
Thanks!
PostPosted: Thu Apr 25, 2013 9:18 pm
It will work but not that well. Those protrudy things are called pinns. The help lift the chain from the little to the big ring when you shift. The too wide 9 speed chain will tend to catch on those pins when you are cross chaining.
For certain parts stiffer is more important than lighter.
PostPosted: Fri Apr 26, 2013 8:40 am
I've been running it on several bikes (three road, two mtb) for a while (several years on the road bikes), with no issues.
Works perfectly, no noticeable difference in the cross chaining side of things either, still can't get the two top sprockets (12/13) from the small chainring on the road bike, same as with a full 9 speed set up.
Mountain bike's a bit different as i went triple 9 speed to a double 10 speed chainset. But i get the same loss of gears (11/12) as on my road bike. But all the gears i can't get, i a) wouldn't use and b) are duplicates anyway.
PostPosted: Fri Apr 26, 2013 12:21 pm
Thanks guys for the info about the protruding metal portion as pins, and no issues running with 9 speed cassettes :)
btw mattr, u mean u cant shift to the smallest rear cogs while on 10 speed chainset and 9speed chain/cassette?
PostPosted: Fri Apr 26, 2013 12:41 pm
Correct.
But then, you usually can't use those gears running an all 9 speed system either.
I have found on the MTB that its the big-big combinations that are "needed", rather than the little-little. And it'll go in to them without any complaints.
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
736
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. 11 speed chains
in Wanted
Pschnei3
Mon Dec 04, 2017 3:59 pm
Pschnei3 View the latest post
There are no new unread posts for this topic. 11 Speed on 9 speed crank set?
Willem
Sat Apr 22, 2017 4:13 am
Willem View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
There are no new unread posts for this topic. Mixing 10 speed sram and 11 speed 105
jowen
Mon Mar 06, 2017 8:40 am
kulivontot View the latest post
Users browsing this forum: Baidu [Spider] and 3 guests
cron
