Xtr on sram casette
michel2
Location: somewere floating between here and the other side
by michel2
Hi all,
Im about to buy a set of xtr shifters and derailleur, my current bike has sram gear on it.my plan is to run the shifters and derailleur on the current sram casette and chain and replacebthem when there wornout with shimano gear.
My questions is: is this going to work or do i find myself in trouble doing this ?
Thanks, mick
Asymptotic
by Asymptotic
Ok - assuming it is all either 9spd and 10spd
I did this for no other reason than that I could get the Sram stuff a lot cheaper. Never had any issues, would say that Shimano chains shift better than Sram though.
Norwood & Adelaide Uni CC
TheRookie
by TheRookie
They use the same standard, so no issue as long as you match 'speeds'.
Personally prefer Shimano cassettes, KMC chains and no preferance on mech/shifter.
02GF74
by 02GF74
TheRookie wrote:Personally prefer Shimano cassettes, KMC chains and no preferance on mech/shifter.
as above. I like the reassuring clunkiness for SRAM but like even better the latest Shimano shifter with teh 2-way shift lever.
