Problems with 2011 Sram XX Disk Brakes
nrsnow
by nrsnow
Are there known issues with 2011 Sram XX Brakes?
Ridley Excalibur
Scott Spark LTD 8.15kg (retired)
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
grover
by grover
What issues are you having. The magnesium ones had issues with reaction with the brake fluid and variable lever feel. There was also a batch with poor tolerance on pistons resulting in contamination and sticking.
nrsnow
by nrsnow
There's a set of used ones that i'm looking to buy.
Ridley Excalibur
Giant NRS (Retired)
socratease
by socratease
Grover is correct.
Buying a used set of these would be a terrible idea, unless you like brakes that don't work.
thisisatest
by thisisatest
There were also issues with incorrect brake fluid eating the seals, excess assembly grease clogging ports up, the occasional disintegrating brake pad (only saw that once), inconsistent bite point... You get the point.
nrsnow
by nrsnow
Thanks guys, i'll stay away from them. I assume the 2012, and 2013 version's don't have these problems. Is it safe to say this?
Ridley Excalibur
Giant NRS (Retired)
02GF74
by 02GF74
I bought a pair of these and have none of the problems mentioned - google SRAM XX and you will find lots of horror stories so best avoided. My are the later version identified by the bleed port being cast in the body.
Zachariah
by Zachariah
Avoid XX brakes altogether....if you value your teeth.
Due to the urging of all the ladies...I do NOT shave my legs!
