It is currently Tue Jan 23, 2018 11:11 pm
 Post subject: New 29er Rigid Build.
PostPosted: Sun Apr 21, 2013 10:45 pm
Carbon 29er frame and carbon fork
Sram XX brake, shifters, cassette, derailleurs
Thomson Masterpiece layback post
Syntace F99 stem
Easton EC90 lowrise carbon bars
Ashima rotors with aluminum/ti bolts 3 each per wheel
FSA carbon cranks (32t spiderless chainring)
Eggbeater SS pedals.
Token light weight BB
Omni racer 9g seatpost clamp.
Fizik Arione CX saddle
ESI grips
Stan's Crest ZTR
Schwalbe Furious Fred Evolution 29er Tyre
Stan's sealant
The bike is actually built up. I am just sorting out the shifting on the rear. Need to install the right length of chain as the one currently on there is a shade small.
Right now the end result is 16.75 lbs. I am thinking that I should be able to get this down to under 16 lbs.
Front wheel
Rear wheel
160mm rotors
3 x Ti and 3 x Aluminum bolts. I have run this set up for years.
Here she is waiting for some tires, chain, shiifter cabling and for me to run the rear brake internally. Need to place my order on CRC for the items.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Mon Apr 22, 2013 10:09 am
Administrator
Very nice Bman.
FWIW The KCNC rotors in 160mm are about 10 grams lighter each. It all counts right?
RESIDENT GRUMPY OLD MAN.
PostPosted: Mon Apr 22, 2013 1:53 pm
Good to know as I can put this on another build I have which will help that build get down to 18 lbs.
BIG DADDY B FLOW
PostPosted: Mon Apr 22, 2013 8:05 pm
Looking promising, those forks look massive!
What tyres you got planned for it?
PostPosted: Mon Apr 22, 2013 8:36 pm
Sorry my post was not the normal type and the information was scattered.
I already have the Schwalbe Furious Fred Evolution 29er Tyre which are working very well. I would like to go something lighter but I will kill these ones first then go lighter. I do love the feel of these on the trails I ride. I also have to admit I am really loving tubeless and will be going that on my other builds.
BIG DADDY B FLOW
PostPosted: Tue Apr 23, 2013 9:09 pm
Nice bike! Looking forward to seeing how this turns out.
S P L I T: 2010 Meivici: 14.4 lbs | 2003 Odile: 19 lbs | Hunter Cycles Cyclocross: 17 lbs | 2013 Dundee Cycles Jewell 29er: 17 lbs
PostPosted: Tue Apr 23, 2013 9:35 pm
I need to button up a few things but since it is 20c here in Vancouver today, it is a great day to do a shackdown ride. Will try to snap a few pictures.
BIG DADDY B FLOW
PostPosted: Sun May 05, 2013 2:14 am
where is the tires?
www.speedercycling.com
Just riding...
PostPosted: Sun May 05, 2013 3:16 am
On the bike! In the garage!
BIG DADDY B FLOW
PostPosted: Sun May 05, 2013 3:25 am
Here is a quick picture. Saddle not at right height. Just took it out of the work stand.
Will get a new post and saddle to drop some weight and need to strip the cranks to bare carbon.
BIG DADDY B FLOW
There are no new unread posts for this topic. Rob English | Mudfoot 29er Rigid
Denavelo
Tue Jan 02, 2018 11:03 pm
jemima View the latest post
There are no new unread posts for this topic. 26" MTB rigid fork
in MTB
wlwoodruff
10
1552
Sun Mar 26, 2017 8:52 pm
thelifeofapanca View the latest post
There are no new unread posts for this topic. Specialized chisel rigid fork 29
Sir Rides a Lot
Sun Jan 14, 2018 10:28 am
Sir Rides a Lot View the latest post
There are no new unread posts for this topic. Lefty Rigid Fork by Flatland
FlatlandBicycles
Thu Feb 23, 2017 6:20 am
UpFromOne View the latest post
There are no new unread posts for this topic. 29er stems
in MTB
burglarboycie
15
1268
Fri Jan 12, 2018 4:25 pm
DurianGrey View the latest post
Users browsing this forum: No registered users and 1 guest
