It is currently Sat Jan 20, 2018 8:32 am
 Post subject: Best chainring bolts?
PostPosted: Sat Apr 13, 2013 1:08 pm
First of all, lets limit the discussion to aluminium or titanium bolts. I know that steel bolts are fit and forget, but hey, we are on the weight weenies forum after all. In addition, they must come in black and have a nice finish. I suspect the black requirement takes most of the titanium bolts out of consideration. Finally, they must be intended for 3-speed cranksets, in this case a THM Clavicula.
PostPosted: Sat Apr 13, 2013 1:22 pm
I got some pretty nice black Ti bolts for my brake calipers from R2. What's the problem with black Ti bolts?
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Sat Apr 13, 2013 1:34 pm
No problem, just that black ti bolts are not that common, especially when compared to aluminium ones. Additionally, is the added weight of ti worth it in this application?
PostPosted: Sat Apr 13, 2013 3:17 pm
Aluminum is fine for chainring bolts, except maybe on a tandem. Alum is lighter by about 1/3 than Ti. Alum is easier to get in colors.
For certain parts stiffer is more important than lighter.
PostPosted: Sat Apr 13, 2013 6:24 pm
Aluminium, I use Truvitiv as they come with a 5mm/6mm Allen fitting for the male/female rather than the silly screwdriver slot, easy to get, fairly light (19g for a set of 4 for 2 rings) and fairly cheap.
PostPosted: Sat Apr 13, 2013 10:32 pm
if you are in UK, check out the Onza aluminium chain ring bolts on ebay - they have Torx socket so more robust than hex socket.
nothing wrong with with using alloy bolts - top of the range Shimano XTR chainset have them.
PostPosted: Sat Apr 13, 2013 11:11 pm
Alu for many many km. Mine came from Toronto Cycles as part of a very large order switching over to all Alu/ Ti bolts. Can't fault them when super reliable and 6g for 4 bolts (1x10)
PostPosted: Sun Apr 14, 2013 1:03 am
I have best luck with original Shimano alu. bolts(came with xtr-970 crankset) and Extralite Extrabolts. No problems whatsoever.
I cannot recomend KCNC or Tiso.
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
There are no new unread posts for this topic. Chainring bolts torque spec
oldnslow2
Sun Dec 10, 2017 11:46 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Ti Stem bolts
misterq
21
2084
Thu Nov 02, 2017 8:48 pm
misterq View the latest post
There are no new unread posts for this topic. Ti bolts...what places to use them am I missing?
Lewn777
19
2428
Sun Apr 02, 2017 4:19 am
froze View the latest post
There are no new unread posts for this topic. FS: Enve 27,2 seatpost, 2 bolts, like new- NOW 130
cdtf
Tue Nov 14, 2017 2:25 pm
cdtf View the latest post
There are no new unread posts for this topic. Tune Sixpack Crank Bolts
in MTB
Feex
Fri May 26, 2017 4:02 am
Feex View the latest post
Users browsing this forum: Google [Bot] and 5 guests
cron
