It is currently Tue Apr 25, 2017 10:15 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: New WW advice pls
PostPosted: Fri Apr 12, 2013 4:40 pm
Hi
I'm new to the forum, i asked a few WW questions on another forum and was directed to you guys & Gals :)
Basically Ive never been a WW in my history of MTB ownership but after spending my bonus on a new 29er
and feeling the benefits of losing some weight i want to try to go a little further.
Id say my riding is spirited XC/trail center work and i weight 70kg so id like to keep the bike fit for purpose.
i have previously owned 26er's ranging from sub 1K hard tails and a range off 2K full sus 140-150mm travel bikes
Here is my new Ghost (sorry just a standard pic, i cant upload my own pics at work, but shall this weekend)
Spec:
Frame: Carbon/Alloy
Stem: Ritchey WCS 31.8 mm
Fork: FOX 32F 29 Air FIT CTD Remote 110 mm Kashima Tapered 15 QR
Handlebar Ritchey WCS Carbon UD Rizer 9 D 710 mm 31.8 mm
Rear derailleur Shimano XTR 10-Speed
front derailleur Shimano XTR
shifter Shimano XTR SL
Crankset Shimano XTR 42-32-24
Cassette Shimano XTR 10-Speed 11-36
Brakes Magura MT8
brakes Magura MT8 Disc 180 mm
Wheelset Easton EA 70 XCT Wheelset
Shock FOX Float CTD XV Kashima Boost Valve Adjust 100 mm
Weight 10.90 kg (Claimed)
Modifications:
XTR Trail pedals (im going to change to XTR race)
Reverb stealth 125MM drop 380mm length (yes i know its heavy but i do want a dropper)
some heli tape
Ghost neoprene chain stay guard
Hope seat clamp
Hope grip doctor
Richley carbon bar ends
Toppeak sidekick saddle bag inc toolkit connected directly to Prologo integrated clip (i dont use a bag and hate things in my pockets)
1 x Eclipse tube
1 x CO2 25g Threaded Cartridge
genuine inovation air chuck elite
Prologo zero nas carbon seat
Running tubeless RoRo snakeskin
ODI Ruffian grips
Vincero Design's magnetic bottle
Total weight (less saddle bag, inc empty bottle) = 12kg
The weights above where measured on my cheapo ebay luggage scales, does this sound about right ? can anyone recommend better scales ?
So how would you shave weight of my bike ?
Ti bolts ? (which ones ?)
Ti skewers ? (which ones ?)
Wheels ? (looking at easton EA90 XC 90 claimed saving of 329G)
Lighter toolkit ? (i shall weigh it this weekend)
Thanks
 Post subject: Re: New WW advice pls
PostPosted: Tue Apr 16, 2013 11:19 am
I think you've added a bit more weight than that....
Hope head doctors are a waste of time and money, stock bolt/cap/SFN is lighter and once the stem bolts are doen up doesn nothing anyway.
Ideally you need to weigh a lot of the bits to understand how to shed weight, Ti is pricey and not necesarily the first port of call.
The lighter wheels would be well worth having.
Do you use all your gears? a 2x or 1x10 conversion will save some weight.
Lose the 1980's bar ends and switch to foam grips, that will knock about 200g off.
PostPosted: Tue Apr 16, 2013 7:55 pm
Biggest bang for the buck: wheels.
Most expensive upgrade: wheels.
I would first recommend you dump the 3x10 setup, and move to a 2x10. This will drop the weight of the extra plate, and remove some of the duplicative gearing found in the 3x10 setup. Odds are, you never ride the big ring anyway. To do this, you'll also have to replace the left hand shifter to a 2-speed model, as well as the equivalent FD. No weight advantage to speak of for the later two, but necessary.
once that is done, look at the wheels.
Madone 9 http://weightweenies.starbike.com/forum/viewtopic.php?t=143973
Crockett http://weightweenies.starbike.com/forum/viewtopic.php?t=130567
Madone 5, Madone 4, SpeedConcept, Cobia
I own a lot of Treks.
PostPosted: Tue Apr 16, 2013 9:24 pm
^ there is only one XTR shifter, there is a small screw you turn to convert between 3 and 2 speed. You would likely need a new front mech though.
If the budget allows, carbon wheels will be the biggest noticeable improvement I would say. the EA90's aren't even 100 g lighter than the EA70's. The EC90's are quite a bit lighter though.
There are no new unread posts for this topic. need advice on wheels..
addict
Mon Jun 13, 2016 5:48 pm
addict View the latest post
There are no new unread posts for this topic. New to CX - 1x groupset advice
clipsed
11
1574
Tue Jul 05, 2016 11:25 am
ooo View the latest post
There are no new unread posts for this topic. New build, need advice
jrobart
Thu Jun 16, 2016 3:57 pm
mimason View the latest post
There are no new unread posts for this topic. THM Fibula - Need Advice
jimaizumi
16
880
Tue Jan 17, 2017 11:38 pm
jimaizumi View the latest post
There are no new unread posts for this topic. Attachment(s) Handlebars Advice Please
ScapinBoy
9
1047
Fri Jun 10, 2016 4:01 am
ScapinBoy View the latest post
Users browsing this forum: Baidu [Spider] and 6 guests
