It is currently Tue Feb 28, 2017 7:00 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: 650B Fork recommendation
PostPosted: Sun Apr 07, 2013 12:07 am
I am hoping to find a 650B compatible fork that I can run something like a Nobby Nic or Rocket Ron 2.25 tire in. It seems that the Magura TS8 R 650 would work. Reading about the fork and looking at the design, I like it, and I'm looking for something in a 100/120mm travel, so that seemed like a great call.
But, I saw that X-Fusion's 100 fork can be converted to a 120 and vise-versa (if I read it right) and that sounded great to me in order to tune the bike better for various kinds of riding. Can you do the same with the Magura fork? For a hard tail, would you recommend one length vs. the other? I've read that the magura fork is better than the x-fusion, would you agree, and if so how much better?
I'm looking for something that is low-maintenance, responsive, and preferably light. This is a first MTB, so any input would be very helpful.
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
PostPosted: Sun Apr 07, 2013 10:06 am
I have a friend who have ridden the magura extensively. He swicthed to fox due to the low mileage he could get out of a magura fork before it needed service. Servicing it is quite easy though.
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Sun Apr 07, 2013 11:00 am
I'm using an X-Fusion right now and I have to say that I am very impressed. Pretty limited adjustments but it just works. As plush as any Rock Shox I've ever ridden and better than any Fox. When you factor in the price they are a stunning fork.
PostPosted: Mon Apr 08, 2013 2:44 am
Another vote for X-Fusion Velvet here. Great fork for the money! Only a single air chamber to set but they are plush ...
PostPosted: Mon Apr 08, 2013 6:38 am
http://german-a.de/
PostPosted: Tue Apr 09, 2013 7:06 am
I'll third x-fusion. Very impressed with their 12-13 offerings. After the inital break in they work extremly well (changing a setting actually works), sold all my Fox's and not looking back. My second choice would be a Lefty, I have one on my Litespeed Niota and will likey be selling it to keep everything in my MTB stable the same across the board.
PostPosted: Wed Apr 10, 2013 2:07 am
Thanks for the feedback. I figure if the picky buggers that tend to populate this site like the x-Fusion, that may be the way to go.
From talking with local MTB people I think I'm just going to go for a 100 travel and not worry about being able to adjust it, but since I guess you still can, then there's no drawback.
Does anyone have feedback about a tapered steerer or straight 1 1/8? I thinking about just doing the tapered with the thought that when I get an FS frame I'd do that with the tapered version and this way I'll have redundant parts that could be swapped back and forth if something happened to one bike or the other and I needed to pilfer parts in the short term.
PostPosted: Wed Apr 10, 2013 5:46 am
I went straight as you can always use straight on a taped HT but not the other way around (I tend to swap equipment around). I was always under the impression the extras stiffness was in the HT not the fork.
PostPosted: Thu Apr 11, 2013 9:23 pm
I hear you about that, but then I'd need to have a reducer crown race around in case I did need to make the switch. I should be at or under 70kg when I start racing again, so I'm not sure that the additional stiffness is required from the tapered head tube, but I also expect that carbon fork crowns and tapered headtubes integrated into those will become the standard in the future, so my thought is to go with where I think the technology is going rather than stick with what I could get away with in order to get the maximum weight savings in the near term - the issue being designing the bike for the right stack, unless I got the tapered headset and did just use a reducer crown race rather than going with the straight 1.125 internal...
There are no new unread posts for this topic. lightest 650b tire ?
in MTB
crazyeight
Sat Oct 29, 2016 6:13 pm
RedCoke View the latest post
There are no new unread posts for this topic. 650B build advice need
in MTB
stormur
13
917
Mon Aug 08, 2016 5:09 pm
stormur View the latest post
There are no new unread posts for this topic. Niner RLT Steel 650b max tyre clearance
jeroenfl
Tue Feb 28, 2017 2:42 am
jemima View the latest post
There are no new unread posts for this topic. Need Tubular recommendation
mnmasotto
Sat Jul 02, 2016 6:27 pm
Zoro View the latest post
There are no new unread posts for this topic. Need saddle bag recommendation
addictR1
9
970
Thu Jun 23, 2016 7:19 pm
eaglejackson View the latest post
Users browsing this forum: Wheely and 6 guests
