X9 Chainring Bolts
FIJIGabe
by FIJIGabe
Hey guys,
I've done a search through the forum, but cannot find an answer to my question. I bought an X9, 2x10, 36-22 crankset. This set comes equipped with a bashguard that I do not want, so the bolts are too long (7mm long). What chainring bolts do you guys use? I found that KCNC makes a set of bolts, but I'm not sure they are a match for what I need (I believe I need a 5mm set). Can anyone provide a link for the correct bolts?
Thanks.
TheRookie
by TheRookie
Angle single specific will do, so yes the KCNC singles will fit fine.
FIJIGabe
by FIJIGabe
excellent. any idea what to use for the 22-tooth ring? same ones?
TheRookie
by TheRookie
Yes just the originals...
