It is currently Sun Dec 17, 2017 5:11 pm
PostPosted: Sun Mar 24, 2013 10:28 am
Hey guys.
Can anyone recommend a light weight stem expander for carbon forks ?
Ideally I want the long one as I struggled keeping it tight before, so something like this:
Thanks in advance :D
PostPosted: Sun Mar 24, 2013 10:48 am
http://r2-bike.com/extralite-ultrastar2
No need to look further ;)
PostPosted: Sun Mar 24, 2013 10:54 am
Thanks for that :D
This is what she looked last time I banged the rigid forks on.
Not sure you can see but, the way I have the stem and the spacers it was like it wasn't gripping and I had to use 10n/m of torque to get it to hold.
I swapped a spacer about and so I was left with a bigger gap at the top of the steerer to the stem and it made a difference so I was wondering if I needed a longer stem expander or not ?
Do you think that would be suitable enough to hold it tight and keep the um, 16 stone of ballast safe on the bike lmao.
PostPosted: Sun Mar 24, 2013 11:11 am
Are you using assembly grip paste between the steerer and stem? Highly recommended.
also, are those aluminum steerer clamp bolts? They look red anodized...
Make sure the bolt threads are well greased, and hopefully not aluminum for that application.
PostPosted: Sun Mar 24, 2013 11:16 am
Yes I use this, Pace RC005:
I did use red aluminium steerer bolts but I learned me lesson since then and I dont use them anymore.
I just don't want to spend a lot of money on this to find it doesn't hold or not suitable for a mans weight lol.
PostPosted: Mon Mar 25, 2013 3:32 pm
You could try and track down one of the new Cannondale expanders,
http://www.cannondaleexperts.com/Cannon ... p_106.html
PostPosted: Mon Mar 25, 2013 5:47 pm
Cheers for the linky Colin :)
PostPosted: Mon Mar 25, 2013 10:01 pm
I glued in the center part of a expander in the steerer with epoxy-glue. It was around 10 gram and is rock-tight
There are no new unread posts for this topic. Upgrading my Front end ( Handlebar, stem , expander
jobvisser
Sat May 27, 2017 12:16 pm
r33prman View the latest post
There are no new unread posts for this topic. Light weight vs aero - my take
in Everything wheels
mike001100
22
2196
Tue Jun 20, 2017 1:28 pm
mellowJohnny View the latest post
There are no new unread posts for this topic. Light weight rotors
in MTB
AllenMtb
13
2121
Thu Mar 30, 2017 4:05 pm
gtinut View the latest post
There are no new unread posts for this topic. Bars and stem - stiffness versus weight.
BennyC
Sun May 28, 2017 8:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. New light-weight Recon cassette
tantra
Tue Sep 05, 2017 9:48 am
Delorre View the latest post
Users browsing this forum: No registered users and 9 guests
