Looking for a 400mm long, 27.2 25mm offset post, sub 200g
by benread
Hi fellow Weight Weenies, I'm looking for a 400 mm, 27.2 mm, 25 mm offset seat post for my new 2013 Trek Superfly Elite SL, SUB 200 grams if possible... and Tune speed needle compatibility... Cheers! :D
by CGT
There are even lighter ones, but that one fits your requirements spot on.
by benread
Thats the exact post I was looking at, however, Its not the lightest, Its quite expensive, I hadn't heard it was compatible with the Tune speedneedle and people seem to be having problems with the clamping mechanism...
by serum
what about http://newultimate.com/seatpost/seatpost-setback" onclick="window.open(this.href);return false; ?
Rotor SP1 is 15 grams over your weightbudget, but i don't know if you need the full 400mm?
by lyot
A new or used one ?
by benread
New and MUST be 400 mm...
by steve147505
hi Try the Eriksen ones not quite able to sneak under 200g ( my 360mm one is 209) but superior clamping mechanism and comfortable to boot
by quantum_Rider
I have been after a similar seat post, 400mm 27.2 with some offset.
Eriksen sweetpost head has notches:
while enve head design relies on wedges to create compression:
Torque meter recommendation for Eriksen 12-15Nm and for Enve 8-12Nm
I would not expect have problems with either design. Still lighter and cheaper ones exist.
by the_marsbar
Top-clamping (Enve) is better for carbon-railed saddles, no?
by Dennis
Woodman has some seatposts on there website with 25mm setback in this size. They are all claimed well under 200 gram. I don't know there real weights.
