Post new topic Reply to topic  [ 9 posts ]
PostPosted: Fri Mar 08, 2013 10:49 am
Hi all,
I have just come by a new frame which takes a semi-integrated headset...
What light, reliable headset should I go for that doesn't cost the earth (say under £70)? As close to 10mm stack height as possible is a bonus too.
Most headset seem to be around the 70-80g mark which is good but if we can go lower that is great :)
Cane Creek 10 Series Zero stack is listed as the lightest from Cane Creek, 62g (starnut and top cap not included in this?) for £30. The only issue is many parts are listed as being "polymer" which screams fast wearing to me especially when this cheap. The 40 series headsets go up to 89g which is not so impressive. Maybe 89g is good if it includes a heavy, top cap, bolt and starnut???
FSA headsets seem quite weighty but cheap.
Tune Bubu is around 65g (minus starnut, top cap and bolt) has a very low stack height but costs a fair bit (140 Euro). I am also not sold on Tune's general reliability.
The Extralite Scalhead seems like the only true WW option at around 45g (minus starnut, top cap and bolt), but is pricey again and the bearings look far too tiny to last too long in a British Winter (or Summer for that matter!). Any thoughts or experiences?
So it appears anything around the 60g mark (minus starnut, top cap and bolt) is pretty Weightweenie.
The only option besides going for reliability in the form of heavy Hope or CK seems to be "Mortop".
http://www.purebike.fr/en/mortop-m78/mortop-hi-65-semi-integrated-headset-a1248.html
60g for the headset, 65g with top cap and bolt for £30 seems pretty good :) Also says 5.2mm stack height :shock: The only problem is many users on other forums report play particularly in the upper race, most likely due to the absence of a compression ring to take up any play. :(
So where does that leave recommendations for a light, reliable and cheap(ish) headset? Should I pay the extra for Tune? Will the durability be ok? Or should I take the hit on a few g's and go with Hope/ Cane Creek/ CK?
Many thanks in advance!
DanW
PostPosted: Fri Mar 08, 2013 11:04 am
I would also add to the list the KCNC Radient R2, £80, 64g for headset only (so 80g ish all in).
Any thoughts?
Extralite or Tune Bubu seems like the only real WW options but durability concerns me. Everything else seems much of a muchness weight wise :/
PostPosted: Fri Mar 08, 2013 4:23 pm
I would go with Chris king, don´t know the weight but it is fit and forget! :D
Sorry for my bad english!
PostPosted: Fri Mar 08, 2013 4:33 pm
I have an regular (external) CK and have been very happy with it but am curious as to lighter weight when swapping the frame and going to semi-integrated headsets...
PostPosted: Fri Mar 08, 2013 10:52 pm
Chris King does a semi-integrated headsets nowadays.
I have both Tube BuBu and KCNC Radiant. No problems whatsoever with both.
Split bottom race is very useful. Aluminum top race(the one that gets rid of play) makes any headset more durable and smooth. I had problems with other headsets where this part is made out of plastic/derilyn and wears out.
I can remommend both. BTW what frame did you get?
Chris.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Sat Mar 09, 2013 9:30 am
Acros perhaps?
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Sat Mar 09, 2013 2:38 pm
Acros are reasonably weighty and also pretty expensive so offer much the same as Hope/ CK as far as I can see. They were definitely in my mind though.
Chris, good to know that you have good experiences with both the Tune and KCNC. At present I am tempted to go for KCNC if bottom races are easily available as it is light, has low stack height and is £30-40 cheaper than Tune.
New frame is a Merida 96- really looking forward to my first proper WW frame/ build! :-)
PostPosted: Tue Mar 26, 2013 6:42 am
Cane creek 10s are garbage. SCHWARBAGE. However, the 40s and 110s are fit and forget.
PostPosted: Tue Mar 26, 2013 2:41 pm
The Cane Creek 110 series stuff is the best available in my opinion.
For certain parts stiffer is more important than lighter.
Users browsing this forum: No registered users and 9 guests
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2598
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. Light reliable tubes?
in MTB
nrsnow
9
813
Fri Jul 20, 2012 2:51 am
nrsnow View the latest post
There are no new unread posts for this topic. Light, strong, reliable and inexpensive skewer
in MTB
lowpsihighspeed
18
1194
Fri Apr 26, 2013 12:37 am
thewatchtech View the latest post
There are no new unread posts for this topic. Low dust cover for integrated headset
in MTB
miceden
Tue Oct 30, 2012 6:25 pm
RollingGoat View the latest post
There are no new unread posts for this topic. Storck integrated headset too tight
topcarbon
Wed Jun 13, 2012 12:16 am
Mile Ditch View the latest post
It is currently Sun May 19, 2013 7:27 am
