Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
PostPosted: Sun Feb 17, 2013 3:55 pm
Hi All :D
I have a titanium project going on and I am about to make the final decisions.
My choice of crankset will be XTR (but I don't know if I am riding Shimano in 3-4 years). That means that I actually do not need PF30 right now.
The question that I find hardest to answer is whether I should go for a BB30, PF30 or BSA bottom bracket.
I know that this question some time turns out to be a question about religion, but anyway....
Please help me out here - BB30, PF30 or BSA.
Ciao
ebsilon
Speed of Lite
PostPosted: Sun Feb 17, 2013 5:14 pm
Seeing as XTR cranks have a 24mm spindle you might as well go for normal BB threads as you will not get the full benefits of BB30 but you will possibly get the hassle of regular bearing replacements and creaks. To me BB30 and PF30 are not an advancement at all.
www.thecycleclinic.co.uk
PostPosted: Sun Feb 17, 2013 7:04 pm
is there not an option for PF92? that way you wouldnt get and creaks from the BB threads and they seem to last longer.
PostPosted: Sun Feb 17, 2013 11:25 pm
You could use a BB92 cups but really whats wrong with BSA threads. They have worked fine for years. Go with BB92 if you worry about how stiff your cranks are. If you do worry about that then you really should find something else to worry about.
I suppose one deciding factor would be is a BB92 shell more expensive than a BSA shell.
PostPosted: Mon Feb 18, 2013 5:13 am
PF30. So many options. Don't make a mistake by going with something else.
PostPosted: Mon Feb 18, 2013 7:21 am
My Form Prevail Ti 29er I got with a PF30 BB, and my latest Ti bike I was going to go that way also. But then I was convinced by the builder to go with BSA 73mm. I've heard all the arguments about this better than that... but what settled it for me was two things:
1) Ease of working on: if something is wrong with your PF30 BB, eg creaking, or binding, etc then good luck servicing it. You'll probably destroy the cups of the BB in trying to remove it (assuming it was loctited in place as it needs to be to not creak). With BSA its obviously very easy
2) Bearing stance: on the PF30 bike I have hollowgram cranks and the bearings are 73mm outside to outside. On the BSA bike I also have hollowgram cranks, installed with a Rotor BB and the bearings are 73mm inside to inside. That's a significant increase in bearing stance that should make the cranks stiffer and the bearings last longer.
To me the above outweighed any perceived benefits of the PF30 system.
Enjoying my Funk
PostPosted: Mon Feb 18, 2013 8:53 pm
I had a Moots RSL with a PF30 bb. I must say that I did not love the PF30- too many issues with bearings, creaking, etc.
If I were to get another ti hardtail I would get a threaded bb and put a King bb in it- done.
PostPosted: Wed Feb 20, 2013 2:07 am
I think BB92 or BB386 would be idea. That way you can keep the BB as wide as possible so you can optimize the downtube and seatstays for stiffness. The weld area could be bigger as you can work the Ti tubes to have the right shape factor at the weld area.
BB30 is still a narrow bottom bracket shell. PF30 is the same.
BB92, or BB386 is where it starts really getting wider and get really optimized.
http://www.hackracer.com/
PostPosted: Wed Feb 20, 2013 3:37 am
I've seen quite a few ti frames with downright awful bb shell tolerance issues. like over 1mm variance in shell width at different points, non-round pf30 bores with up to 0.5mm interference, etc. Larger spindles are less tolerant of misalignment than smaller ones. Some shops won't ream/face ti frames as they're hard on cutting tools, and most don't have the tools to do it to a nonthreaded frame.
whichever you choose, make sure they properly finish it.
PostPosted: Wed Feb 20, 2013 4:29 am
for BB30 you have to do the boring of the bottom bracket post weld & heat treat (if you need heat treat for your particular metal).
PF30 relaxes the tolerances a bit and uses a cup to take up the tolerance required.
PostPosted: Wed Feb 27, 2013 10:02 pm
What about BB86. It's the Shimano standard. It doesn't have the squeaking issue that BB30 has. It blows all the other standards away.
PostPosted: Fri Mar 01, 2013 9:43 am
This is the exact reason I'm on the fence about replacing my current MTB (Ti Litespeed Niota) most of the current ti offerings are all PF30 and after riding with a good friend on a Moots with a PF30 I don't want to deal with the non-stop creaking/squeeking.
PostPosted: Fri Mar 01, 2013 6:13 pm
At NAHBS I talked about this for a while with the builder from Mosaic. He was a proponent of using a BB30 shell (not PF30) with the Rotor BB adapter to 24mm cranks. He liked this because the Rotor BB cups thread together and pull the BB in tight... which prevents creaking he said and allows you to remove and service the BB with simple tools. Praxis make a similar BB I think for PF30 frames. Only downside is that they marry you to 24mm spindle cranks.
Enjoying my Funk
PostPosted: Fri Mar 01, 2013 10:12 pm
So what the point then you might as well have the cheaper convential BB thread and a normal BB.
PostPosted: Sat Mar 02, 2013 12:43 am
I tend to agree with you (see my earlier post). Mosaic seemed to think that the BB30 shell is a "nicer platform to build around". He felt like there were perceived stiffness payoffs with the frame. I'm skeptical myself, but I mention this in the context of people who are anxious about not having a choice by PF30, or who already have a PF30 frame.
Enjoying my Funk
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 10 guests
There are no new unread posts for this topic. PF30 install?
audiojan
Tue Oct 16, 2012 5:10 am
elviento View the latest post
There are no new unread posts for this topic. Where to get BB spacers for PF30?
elviento
Wed Aug 01, 2012 1:24 pm
bikerjulio View the latest post
There are no new unread posts for this topic. PF30 bearing seal removal
styrrell
Sun Mar 24, 2013 9:03 pm
styrrell View the latest post
There are no new unread posts for this topic. SRM 7900 + Wheel Mfg PF30 adapter
ipenguinking
Wed Sep 05, 2012 3:19 pm
TurboKoo View the latest post
There are no new unread posts for this topic. Make your SRM work on your PF30 frames!
ParisCarbon
14
1661
Sun Jan 13, 2013 8:09 am
NiFTY View the latest post
It is currently Wed May 22, 2013 8:48 pm
