Post new topic Reply to topic  [ 14 posts ]
 Post subject: new build advice
PostPosted: Fri Feb 15, 2013 2:07 pm
I'm planning a new build 29er hardtail for XC marathons and one day, the Tour Divide race.
Must be reliable before being light. I have the fortunate opportunity to really splash out
so I was thinking of some special hubs on Enve rims.
Choices are:-
XTR
Royce (from the UK)
Kappius
The disadvantage of non XTR is that I can't use the XTR rotors on the other two 6 bolt hubs.
What should I do? Use XT rotors on the cool hubs or stick with pure XTR?
cheers,
Tom
 Post subject: Re: new build advice
PostPosted: Fri Feb 15, 2013 4:40 pm
Get a centre lock to 6 bolt adapter and use XTR hubs. They are alot lighter and I canot see why they are not reliable.
To be fair to Shimano SLX is pretty good groupset. XTR is twice the price for a little less weight. So on that though I bought new XTR cranks recently and am about to buy some XTR hubs.
www.thecycleclinic.co.uk
PostPosted: Sat Feb 16, 2013 2:34 am
Location: somewere floating between here and the other side
I second that, shimano hubs are excellent ! An keping it simple rules !(;
PostPosted: Sat Feb 16, 2013 4:18 am
The nice thing about the shimano hubs is that they are fully rebuildable, because they still use loose ball bearings.
If you want reliability in a cartridge bearing system, its hard to beat chris king.
PostPosted: Sat Feb 16, 2013 10:58 am
^ +1 for the Chris King hubs, if your going to spend so much on enve rims, may as well get really nice hubs. The Kings are very reliable as well.
Norwood & Adelaide Uni CC
PostPosted: Sat Feb 16, 2013 8:00 pm
CK hubs make XTR hubs look lie good value. I'll e using XTR hubs in my new MTB hubs when I decided I can afford them. I never decide I can afford CK hubs. I have a baby to feed.
PostPosted: Sat Feb 16, 2013 8:07 pm
..on 2000 bucks rims take only the best hubs.... Extralite...or Tune.. :)
..anything else will be inappropriate...
BE a bike raider ,NOT a net surfer!
http://imageshack.us/g/594/pb210794.jpg/
PostPosted: Sun Feb 17, 2013 5:37 am
In the US, King and XTR hubs are nearly the same price. I'd recommend the kings for their superior sealing. If you're concerned about the freehub body holding up, you can always spring for the stainless steel one. Also, the cost difference between hubs is pretty small, especially considering they'll go on enves.
PostPosted: Sun Feb 17, 2013 9:38 pm
Thanks for the advice everyone.
I must admit to doing zero maintenance on my cartridge bearings (and they're in poor condition)
compared to years ago when I used to strip my hubs down regularly.
I've looked online but not seen any 6 bolt to centrelock adaptors, only the reverse, anyway, I would think
the centrelock ring would have to be drilled out?
cheers,
Tom
PostPosted: Mon Feb 18, 2013 12:57 pm
You can't do a 6 bolt to CL adaptor, there is no room, only CL to use a 6 bolt disc.
PostPosted: Tue Feb 19, 2013 5:28 am
cheers,
Tom
Tom,
I bet you would enjoy the CK hubs that much more. The nice thing about them other than the excellently sealed cartridge bearings (which are fully rebuildable, by the way) is that the freehub is CK's awesome ringdrive. Basically it works like a car's transmission with 2 beveled gears that get engaged by a spring. No more broken pawls, and you get the awesome 3 degree engagement that CK and Industry Nine are famous for.
PostPosted: Tue Feb 19, 2013 8:13 pm
As mentinoed, the CKs are a great option. They aren't super light by any means though. If you wanted a lighter hubset, check out the lineup from Tune. They make an awesome product, with consistent durability.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Tue Feb 19, 2013 10:18 pm
Hope hubs. I have been using these for years. Mine are lowly XC Pro's and the rear weighs quite a bit but they have been faultless. Hope Pro 3 are what 380g/pair. That's not heavy and they are reliable. Pro2's are bit heavier and a bit cheaper but no less relaible.
DT Swiss 240, Hope and XTR are my favorite MTB hubs.
PostPosted: Wed Feb 20, 2013 11:33 am
I've had some success sourcing NOS XTR hubs from ebay at good prices.
Bikes: Raceur, Beateur
Users browsing this forum: Exabot [Bot] and 5 guests
There are no new unread posts for this topic. Groupset advice for new build.
n1klass
Sun Dec 23, 2012 5:47 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Need some advice for a CAAD10 build
EPICBYTES
Sat Apr 27, 2013 12:44 pm
EPICBYTES View the latest post
There are no new unread posts for this topic. Budget build advice
in MTB
RollingGoat
9
1451
Tue May 14, 2013 3:53 pm
davestradamus View the latest post
There are no new unread posts for this topic. Cervelo groupset advice for new build
welkman
19
1010
Thu Jan 17, 2013 11:49 am
1415chris View the latest post
There are no new unread posts for this topic. NOS Look KG 233 steel weenie build advice
victorduraace
Mon Apr 08, 2013 4:24 pm
kgt View the latest post
It is currently Wed May 22, 2013 4:09 pm
