Post new topic Reply to topic  [ 9 posts ]
 Post subject: v-brake wheels
PostPosted: Fri Feb 01, 2013 7:52 am
Hi guys I would like to build a set of wheels for v-brakes. Thus far I sourced second hang Hugi 240 Hubs- 95g and 257g. Now I am aware of some rims that come in at about 350 grams each but I would like to go 50 or so grams lower than do you have any suggestions? Also I want to use aerolite spokes with the aluminium nipples- 278g plus 20g. This set up would mean a total weight of approx. 1350g but I think I can go lower. Do you guys have any suggestions? Much appreciated.
 Post subject: Re: v-brake wheels
PostPosted: Fri Feb 01, 2013 10:35 am
Administrator
If you look at all the rims that go sub 350 they are disc only. If doubt you can find a rim that goes low unless someone makes one in carbon?
viewtopic.php?f=100&t=71888
PostPosted: Fri Feb 01, 2013 12:18 pm
The best (and pretty much only) rim brake rim still made is the DT swiss xr440. It is excellent. You may (but I doubt it) find a NOS stans v-brake rim out there somewhere, but it is highly unlikely in 26in format.
PostPosted: Fri Feb 01, 2013 7:47 pm
Don't think your weight target is very realistic, if you contrast that the not many road clincher rims are below 400g. Now 28" > 26" of course, but you want a bit more beef off the road.
I'm going to try a set of 36h A23s this season (in 650b). Do people think that's outrageous? Moderate XC type riding mostly, but you all know how it is when you discover a trail that's calling your name ...
Bikes: Raceur, Beateur
PostPosted: Sat Feb 02, 2013 12:21 am
The only V-break rim I could think of that comes under 350g is Sun Ringle Lime Light. They varied between 310-330g, but I doubt you will ever find a pair anywhere. Easier to find are Sun Ringle UFO but they vary from 360g-390g. Newest Sun Ringle Equalizer are smilar in weight.
I never actually have seen ZTR 355 rim at 350g or less. All in 360's-370's. Mine are 366g and 377g.
Fot your GT why not try to find older Mavic ceramic rims? Mine x-517 ceramic are right at 400g. Not the lightest, but perform much better.
You could always get lighter set of hubs, unless you want to keep the <2000 theme.
Chris.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Mon Feb 04, 2013 5:20 am
Thanks a lot for the advice guys I'll see what I can find... :wink:
PostPosted: Tue Feb 05, 2013 6:31 am
The Mavic 717 is a similar weight the XR440. The Dt rim is better. Remeber for XC riding the brake track is subject to more wear than a road rim will be so thicker braking surface is needed for durability. That is why those Sun rims are impossible to find. They wore out ages ago.
www.thecycleclinic.co.uk
PostPosted: Fri Feb 08, 2013 9:21 pm
I have a set of American classic mtb 26 v brake wheels.
They are 1390 grams on my scales.
See if you can find a pair of these on eBay
PostPosted: Fri Feb 08, 2013 9:47 pm
I think your 240 hubs with DT Swiss XR440 rims with Laser/rev spokes and alloy nipples will be a low 1500's grams. That is light enough.
Users browsing this forum: No registered users and 15 guests
There are no new unread posts for this topic. Best modulating brake pads for carbon wheels?
drmutley
27
1345
Mon Apr 08, 2013 9:31 pm
danielbahia View the latest post
There are no new unread posts for this topic. Cheap(ish) light(ish) aero wheels w alloy brake track
Kurt
19
1897
Fri Sep 21, 2012 10:45 am
Phill P View the latest post
There are no new unread posts for this topic. Alternative Brake Pads for Campag Bora Ultra Two Wheels
RedComet
10
690
Wed Jul 25, 2012 4:18 pm
Calnago View the latest post
There are no new unread posts for this topic. Cole Pink brake pads - Bonty xxx lite tubular carbon wheels
poully
Thu Feb 07, 2013 8:44 am
Max Gravity View the latest post
This topic is locked, you cannot edit posts or make further replies. carbon wheels VS alloy wheels
joe77bike
Fri Jul 06, 2012 5:55 am
Frankie - B View the latest post
It is currently Sat May 25, 2013 8:57 pm
