Post new topic Reply to topic  [ 5 posts ]
PostPosted: Tue Jan 29, 2013 4:39 pm
I recently picked up a 2004 (Horst Link) 5-spot frame with upgraded RP23 boost valve shock. It is size 'small', so I thought I would build my wife (yet) another bike (which she will probably never ride!).
The frame is now at the finishers waiting to be stripped and powder-coated (RAL 6027 which is the original Gulf Racing Blue colour). After that, I have new downtube decals, a new (new style) metal headtube badge and some fresh zerks to go on.
The current spec (with published weights reads as follows):-
5-spot frame with RP23BV shock and all linkages/bushing etc - 2,250g (remember, it is a tiny frame!)
DT Swiss EXM130 QR fork - 1,645g
Hope Pro 3 SP XC3 wheelset (Stans 355 24-spoke SP with 3-bolt rotors) - 1,483g (complete with rim tape) **actual weight
Hope 3-bolt 160 & 185mm rotors - 200g
Schwalbe Ro'Ro 2.25" and RaRa 2.25" EVO folding tyres - 1,000g ** actual weight
Stans valves and sealant - 180g
Lock-On grips - 120g
Superstar 9mm bolt-through QR (front) and 10mm QR (rear) - 190g
Formula RX brake levers & calipers - 550g
FSA Carbon Pro handlebars - 250g
Fizik Arione Dione saddle - 210g
Seatpost collar - 20g
Thomson X4 80mm stem - 150g
Ks i7 Supernatural dropper post with remote (27.2mm) - 609g
2x10 SLX groupset with 38/24 front and 11-36 rear plus XT shadow+ (clutch) rear mech inc cables - 2,173g
total estimated weight (less pedals) - 11,030g (24.3lbs)
for pedals may use the indecently heavy Shimano SPD Trail pedals at circa 455g
i also have a FSA carbon pro 27.2mm seatpost which I could put on to save weight (will save approx 350g) but that would rather defeat the AM focus of the bike.
i will post up pics and actual weights as i start to put it all together.
hope you enjoy!
viewtopic.php?f=10&t=109022
viewtopic.php?f=10&t=109000
viewtopic.php?f=10&t=105626
PostPosted: Thu Jan 31, 2013 5:29 pm
Your wife is lucky! I built my gf up a mtb around an on-one inbred frame from bits and bobs I had lying around. Somehow it's heavier than my 29er...
Good luck - look forward to the pics!
PostPosted: Wed Feb 06, 2013 5:58 pm
i really must stay away from CRC... i now appear to have a brand new Fox RP23 Float Kashima-coated shock in the exact right size for the 5-spot, complete with the right reducers and essentially the right level of tune... hmmm... her bike is going to end up nicer than mine!
PostPosted: Fri Feb 08, 2013 9:19 am
If you are looking for lighter option on grips, try these http://store.ibiscycles.com/ibis-clamp- ... -p105.aspx" onclick="window.open(this.href);return false; they are really comfortable and nice and small in diameter :-)
PostPosted: Sun Feb 10, 2013 11:13 pm
I use handlebar tape.
Alhoa
Users browsing this forum: Bing [Bot], Exabot [Bot], rmerka and 8 guests
There are no new unread posts for this topic. First time lightweight project build
TomCastellani
Tue Oct 16, 2012 1:07 pm
TomCastellani View the latest post
There are no new unread posts for this topic. My Felt F1 build... First weight weenie project
austinla
Tue Mar 19, 2013 6:29 am
Saoi View the latest post
There are no new unread posts for this topic. Attachment(s) Project Black - Miracle MC066-SL Build
system787
19
3980
Sat Oct 20, 2012 7:50 pm
stef32 View the latest post
There are no new unread posts for this topic. 2012 Scott Foil 15 project build - HELP
addictedr1
Mon Mar 11, 2013 7:14 pm
esuuv View the latest post
There are no new unread posts for this topic. Flyxi FR-009 Carbon bike sub 8 kilo build [New Project]
Psyclist
14
2597
Wed Aug 08, 2012 3:23 pm
Psyclist View the latest post
It is currently Mon May 20, 2013 4:31 am
