Tell me about Lefty steerers -- e.g., MCFK, EP, etc.
Mattias Hellöre
by Mattias Hellöre
Yes it can be stiff or whatever BUT, original cannondale steerer tube, the older ones are around 115 grams, your point is here. Save weight and using a 1 1/8 inch stem?
My tubes are consistently hovering around 75-80 grams for standard ones. Have made as low as 62 grams, as high as 99 grams.
Experimental Prototype
seismic
by seismic
Do not see the problem with a 1 1/8 stem. Could you please elaborate?
Mattias Hellöre
by Mattias Hellöre
Fo a total freedom of stem choice, go for 1 1/8 inch steerer tube, but for best stiffness/weight - ratio a combo with steerer tube. stem and handlebar is best option but limitations are fixed angle and in a crash which destroys your handlebar, you are forced to replace the combo.
Lightest stems in 1 1/8 is AFAIK Extralite and AX Lightness, they both are not the stiffest either.
trackdawson
by trackdawson
I am curious, for those with the Mcfk steerer, how does the stem interface with the head tube. Specifically how does the crown race attach to the steerer?
dwaharvey
by dwaharvey
Like a normal fork does, aside from the fact that the lefty clamp goes on first and the crown race is pressing down onto: 1) the top of the steerer if it's the 1 1/8->1 1/2 tapered, or 2) the 1 1/2" shim/spacer that the lefty is clamping if it's the 1 1/8" straight version. (crown race is a tight slip fit on the steerer).
trackdawson
by trackdawson
Thanks, until i found this site I was set on the project 321. The split ring under the race of theirs threw me.
awdnut01
by awdnut01
I just replaced my Lefty steerer tube on my generic open mould 29er FS bike (1.5-1.125 tapered head tube) with Mcfk tapered carbon steerer. The 321 steerer assembly that I took out weighs 182gr while the tapered Mcfk carbon steerer assembly weighs 86gr
http://www.flickr.com/photos/117142033@N02/12447997045/
