Post new topic Reply to topic  [ 8 posts ]
PostPosted: Sun Jan 20, 2013 7:36 pm
Just got the bike.
I have been skimming through the owner's manual, and I noticed the part KP123 chainplate. What is this thing for? The reason I ask is that it looks like the top of the FD is rubbing the frame. Like this:
Also, the bike didn't come with a downtube protector (KP054) and scuffguards (KF103). Should I have received those with the bike?
EDIT: The bike also doesn't have protective film on the right chainstay. It does have a neoprene chainstay protector, but I thought it should have protective film as well? Something like this: http://www.cannondaleexperts.com/Cannon ... p_449.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Mon Jan 21, 2013 1:34 am
The flash seat tube always sits very close to the back of the front derailleur. Some particular front derailleurs will not fit due to interference. I can't see yours that well but if it was mounted, it's probably fine.
As I recall, mountain bikes that come with the neoprene chainstay protector do not have s separate clear vinyl protector. I remember the downtube protector coming factory installed, the scuffguards should be provided, I'm sure the place you got it from will just give you some.
PostPosted: Mon Jan 21, 2013 5:17 am
the_marsbar wrote:
Just got the bike.
{/quote]
kp123 is for fitting a shimano FD on there. it is not needed if you are running a sram FD.
no. neither one is supplied as standard.
PostPosted: Mon Jan 21, 2013 8:09 am
Thanks for the replies. I'll ask them if they have any spare protection tape.
I think I'll take a closer look at that FD. I just want to make sure it's OK.
PostPosted: Mon Jan 21, 2013 4:32 pm
Hmm, I don't have the hex wrench to remove the cranks at the moment (10 mm). I thought I had, but I don't. What I did do was to loosen the leftmost screw that holds the front derailleur.
It does seem like the front derailleur is just touching the frame. Should I do anything about this? I am worried that vibrations might cause scratching of the frame.
Could other Flash 29er owners please check how much space is between their front derailleurs and the seat tube?
PostPosted: Sun Feb 03, 2013 11:18 pm
Mine is touching just a tiny bit as well (f29 carbon 3, size L. X7 derailleur.) I removed the derailleur and put a frame saver there (the little clear 3m patches that come with all cannondales) Once tightened down, it compresses the sticker a little bit, but it seems like its going to prevent the frame from getting scratched.
PostPosted: Mon Feb 04, 2013 4:17 pm
hi, marsbar--i wanted to amend something that i wrote earlier.
my scalpel did not come with the downtube protector, but my flash did come with the KP054 part installed, as well as several other scuff guards to prevent cable rub.
i apologize for that confusion.
PostPosted: Mon Feb 04, 2013 4:32 pm
No worries. I bought some coptertape and used that instead:)
skywalker268: Thanks for the information. I might do the same.
Users browsing this forum: No registered users and 4 guests
There are no new unread posts for this topic. Whether drilled frame need a layer of varnish protection?
WasFab
Mon Jul 16, 2012 2:28 pm
WasFab View the latest post
There are no new unread posts for this topic. Frame Cannondale 29 flash, cannondale supersix
dariofox
Mon Mar 25, 2013 10:04 am
dariofox View the latest post
There are no new unread posts for this topic. Placement of the Quarq magnet on a TCR Advanced 2012
Roark
12
604
Sat Jan 19, 2013 12:30 am
djm View the latest post
There are no new unread posts for this topic. Attachment(s) A new secondhand Cannondale frame (did it again)
Rumsas
31
3050
Tue May 21, 2013 8:45 pm
abhisheknath View the latest post
This topic is locked, you cannot edit posts or make further replies. What type of Cannondale frame is this?
havana
Sun Apr 07, 2013 9:07 am
havana View the latest post
It is currently Wed Jun 19, 2013 6:22 am
