Post new topic Reply to topic  [ 24 posts ]
Go to page Previous  1, 2
PostPosted: Fri Jan 18, 2013 2:56 pm
In thats case I'll wait for your verdict on the new bolts as I can't see them being any different than any other bolt. Very curious now... :D
PostPosted: Wed Jan 23, 2013 4:21 pm
Carbocage bolts, a bit better but stripped before I reach 5nm.
Experimental Prototype
PostPosted: Thu Jan 24, 2013 1:58 am
I got my spare part Red bolts today. They are a very good fit in the chainring, and nearly identical in dimensions (differences could just be measurement error) to the bolts that come on the XX1 crank (I have one of those that I got with a group). The only difference is that they are black. See pictures. This looks like the way to go if you want to use an aftermarket crank/spider with XX1 rings...
File comment: Stock SRAM XX1 bolt length
File comment: Stock SRAM XX1 bolt thread diameter
File comment: SRAM Red replacement bolt thread diameter
File comment: SRAM Red replacement bolt length
Enjoying my Funk
PostPosted: Fri Jan 25, 2013 11:15 pm
Very interesting and thanks for posting the info. I tried to find out more myself but apparently XX1 isn't even available in the UK yet (or so two of my local bike shops tell me)! :(
PostPosted: Mon Feb 04, 2013 7:08 pm
I was following this thread very closely because I was waiting for my leonardi sl spider to come in so I could mount the xx1 chainring. Well, it arrived this past week and I had 3 Extralite chainring bolts (for a double set up) laying around and figured I tried them on to see if they would fit. Besides being about 3 mm long (eyeball test so don't hold me to that), they were able to torque up without any problems. Think I'm gonna order me some single speed bolts and start riding the damn thing....
.jpg
PostPosted: Wed Feb 06, 2013 2:48 am
Replaced the Extralite bolts with the Sram Red bolts and it works perfectly Torqued and ready to go.....
PostPosted: Sun Apr 21, 2013 1:36 pm
I know that this is a relatively old thread, but there are now a number of options for those of you looking to fit XX1 style chainrings to your current cranksets. Check out these two articles:
http://bideshibiker.blogspot.com/2013/04/sram-xx1-aftermarket-chain-rings.html
http://bideshibiker.blogspot.com/2013/04/why-do-we-need-or-want-aftermarket-xx1.html
PostPosted: Wed Apr 24, 2013 12:06 am
They're an M8.5x.75 instead of a standard M8x.75
PostPosted: Sun Apr 28, 2013 9:54 pm
Quote:
I like a bash and have heard that it is almost impossible to fit a bash to these cranks
Depends; Gamut (I think) are planning to launch a 104mm BCD spider for SRAM removal spider cranks (ie. X9-XX1, and Truvativ AKA) which will take normal rings and a bash; not helpful if you want to run a ring smaller than 32t, and also means you can't swap chainrings (should you wish to do so) without removing the crank, which is meant to be an advantage of XX1.
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Users browsing this forum: No registered users and 9 guests
There are no new unread posts for this topic. X9 Chainring Bolts
in MTB
FIJIGabe
Thu Mar 28, 2013 10:21 am
TheRookie View the latest post
There are no new unread posts for this topic. Best chainring bolts?
in MTB
CGT
7
206
Sun Apr 14, 2013 1:03 am
krzysiekmz View the latest post
There are no new unread posts for this topic. Campy 11 chainring bolts
fletch62
Tue Jun 19, 2012 2:08 pm
mjduct View the latest post
There are no new unread posts for this topic. Parts of Passion Chainring Bolts
Horacio
Tue Nov 06, 2012 5:21 am
Horacio View the latest post
There are no new unread posts for this topic. Am i crazy??? DA 7900 ChainRing Bolts
Ladeira
Wed Oct 31, 2012 9:26 pm
bikedoc View the latest post
It is currently Sun May 26, 2013 4:11 am
