Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sun Jan 06, 2013 1:31 pm
Hi all,
I am very tempted to try 120mm forks on my Superlight but can't see too many options.
I have Fox FIT 100 RLC's at the moment which I like and 120 versions can be had for £450. This is about the best deal I could expect for Fox I think. Only real problem is that they are reasonably heavy (relatively speaking) and if I were to spend the extra pennies on new forks I would want to drop some weight over the Fox FIT 100 RLC's I currently have.
Does anyone have a real weight for a 120mm Fox FIT RLC's with bolt through?
So my thinking is that if I want something lighter than Fox FIT 120's and reasonably priced then that pretty much only leaves SIDS. It would also seem that only the XX and World cups would drop any real weight over my Fox FIT 100 RLC's when considering the 120mm travel and bolt through (I'd like to stick with 15mm through axle if possible).
How light are 15mm thru axle 120mm SIDS in the various guises and which of the confusing range should I be after?
Magura Durin's (or the new renamed forks) would be lovely but I can't see these particularly cheap anywhere and the 15mm thru axle versions seem hard to come by...
Formula forks look nice but are pricey and I am yet to see proper weights or thorough reviews.
Marzocchi are heavy and I could not handle living with a DT Swiss fork. A lefty would be great in an ideal world but I can't justify the cost of a new wheel build and the out right cost of the properly light Leftys.
So:
Cheap as possible
Lighter than Fox FIT 100 RLC's
15mm Axle
Standard steerer
Not fussed on any lockouts bar or otherwise
Have I pretty much summed it up? Does anyone have any real world weights of various forks with 120mm travel?
Many thanks, DanW
PostPosted: Mon Jan 07, 2013 9:39 am
From Fox the 32 Float CTD are lightest according to the Fox webby, 1.4Kg with 9mm QR, 1.48 with 15mm.
The SID XX WC is quoted at 1366g at 120mm with tapered steerer, so will be a little heavier with a plain 1 1/8th, about the same as the Float CTD at a guess as it tends to add about 100-150g.
PostPosted: Fri Jan 11, 2013 1:33 pm
To be honest I am shocked at Fox's quoted weight for the 120mm fork. Seems reasonably light (for Fox) but then there isn't enough of a weight saving over my current forks to really justify the expense and curiosity. Plus the reviews of the new CTD forks seem very mixed.
That said, does anyone have real weights for the new Fox CTD forks in any of the different flavours?
Any real weights for 2012 or 2013 SID's with 120mm travel and 15mm lowers
PostPosted: Fri Jan 11, 2013 3:30 pm
tapered steerer forks are always heavier than non-tapered in my experience.
For certain parts stiffer is more important than lighter.
PostPosted: Fri Jan 11, 2013 6:36 pm
Interesting as most manufacurers quote tapered as lighter than parallel!
PostPosted: Sun Jan 13, 2013 7:55 pm
go for Formula !
I've tested this one for mountainbike.be and it really is a good fork, about 1450gram, stiff, superb compression....
Users browsing this forum: No registered users and 10 guests
There are no new unread posts for this topic. Which SID 120mm Forks?
in MTB
TheJackal
7
845
Fri Jun 15, 2012 11:34 pm
TheJackal View the latest post
There are no new unread posts for this topic. 28.6 mm light seat post clamp options (under $30.)
LouisN
Sun Jan 06, 2013 11:19 pm
LouisN View the latest post
There are no new unread posts for this topic. Extralite Roadstem UL2 - 120mm 92,1g - 80€
dark_albert
Tue Feb 26, 2013 10:01 pm
dark_albert View the latest post
There are no new unread posts for this topic. LEFTY CARBON XLR 120mm in SCALPEL 80
in MTB
dellpan
Thu Dec 20, 2012 6:15 pm
dellpan View the latest post
There are no new unread posts for this topic. 1.25" (1 1/4) Ritchey 120mm stem.
in Wanted
asdf123
Wed May 15, 2013 9:31 pm
asdf123 View the latest post
It is currently Sat May 25, 2013 3:14 pm
