Post new topic Reply to topic  [ 25 posts ]
Go to page 1, 2  Next
PostPosted: Mon Dec 31, 2012 3:50 pm
Hi
From next year I would like to put on my 26'' HT bike wider handlebar. Whole my life I used handlebars narrow than 600mm,but now I think about 660 or even 685mm. Does someone have some experience with as wide handlebars as that. For me they are more comfortable,and its easier to control the bike riding down the hill.
PostPosted: Mon Dec 31, 2012 5:24 pm
Hi
My bike came with a 685mm handlebar, but I am going to a 720mm as I find the wider bar more comfortable.
PostPosted: Mon Dec 31, 2012 5:48 pm
560mm for me. Nice for marathons and not very technical downhills. I may switch to 580mm, but wider i don't like it. 100% XC
PostPosted: Mon Dec 31, 2012 6:14 pm
I used 520mm for a very long time. This year i switched to a new bike and i use a 600mm with a 20mm shorter stem. What should i say...the good old times are over, and this is good.
PostPosted: Mon Dec 31, 2012 6:32 pm
used to ride 580s.. than switched for 600 on fullsus bike, than kept them on my Litespeed and since I converted to fully rigid bike I also switched these bars for 720 ENVE riser... wouldn´t get back for nothing! 8) love the feeling of having evyrything under control with these... i like to ride bike not been ridden by bike :-D
Not exactly pure Weightweenie.... but still crazy enought to hunt every possible gram (used to be, but still like reasonably light bikes :-))
- LITESPEED Obed
- STORCK Scenario Team
PostPosted: Mon Dec 31, 2012 7:46 pm
Nothing narrower then a 710 for me anymore.
Rapha cycling's Ed Hardy
PostPosted: Tue Jan 01, 2013 2:51 pm
Very good to hear that. I thought,that I'll be the only person with that wide handlebar on 26er.
Thanks
PostPosted: Wed Jan 02, 2013 10:53 pm
745mm
It's no XC rig though...
PostPosted: Thu Jan 03, 2013 12:38 am
600-620. Riding 600 on my 26 fs at the moment. To expensive to change for a couple of cm wider so have to wait.
/jonas l
PostPosted: Thu Jan 03, 2013 7:52 am
on my 26" I run Easton EC90 610mm lo rise bars but I am thinking on my 29er that I am going to run the 685mm Easton EC70 lo rise bars.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Thu Jan 03, 2013 11:23 am
600mm on the 26er ... 640mm on the 29er. I can't imagine wider though ! 700+ ... Damn guys.
PostPosted: Thu Jan 03, 2013 1:46 pm
Was running 580's went to 640's, won't be going back although may drop them to 620....when it's smooth I drop my hands onto the inner bar for an improved aero/pedal position and find I can run about 1 gear higher.
PostPosted: Thu Jan 03, 2013 4:18 pm
XC HT - I was riding about 580 flatbar, then went to 620 low riser and it helped with confidence on technical downhills. Several months later moved back to 590 flatbar with barends and felt no worse on downhills, but better everywhere else, so I'm keeping them for now.
PostPosted: Thu Jan 03, 2013 6:22 pm
One more question,when you changed yours handlebars for much wider like from 580 to 660-80,did you changed stems,or no??? I planning to put 2cm shorter
PostPosted: Thu Jan 03, 2013 11:23 pm
I use my HT for everything (XC, play bike, jumping) and went to a 710mm bar. I also shortened the stem by 10mm. The shorter stem is a little worse on steep climbs but overall a more fun ride on the trails.
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
Users browsing this forum: CGT and 6 guests
There are no new unread posts for this topic. First attempt - rigid SS 26er ...
in MTB
TooSteep
Thu Jan 31, 2013 10:18 am
Martin.F View the latest post
There are no new unread posts for this topic. 650b wheels on a 26er bike?
in MTB
cyclemanpat
7
2568
Wed Aug 29, 2012 4:56 am
Nole View the latest post
There are no new unread posts for this topic. The wide rim craze.
in Everything wheels
Juanmoretime
Sun May 12, 2013 3:18 am
pushstart View the latest post
There are no new unread posts for this topic. FLO 30: New wide clincher wheels
[ Go to page: 1, 2, 3, 4 ]
olebole
48
6245
Mon Apr 29, 2013 5:55 pm
Canadian View the latest post
There are no new unread posts for this topic. wtb wide alloy clincher wheelset(hed c2, h plus, pacenti)
in Wanted
ghostrider1tm
Sun Apr 07, 2013 3:44 pm
ghostrider1tm View the latest post
It is currently Sat May 18, 2013 4:17 pm
