It is currently Sat Feb 25, 2017 3:48 am
PostPosted: Sat Dec 22, 2012 2:54 pm
I've been primarily a road cyclist ... but I live in an excellent location for mountain biking also, and I want to get started.
My questions are regarding fit. Will my road bike measurements translate directly to a mountain bike? I assume saddle height and setback from BB should be nearly identical? Reach and stack is where I'm really not sure. Since MTB handlebars don't have the "reach" of road handlebars, is there a way that people swag this measurement? It seems like you could measure from nose of saddle to "hoods" on your roadbike ... and come up with a close distance for flat mountain bike bars.
Also, is there any reason I can't use my favorite road bike saddle on a mountain bike? I run a Selle Italia SLR Superflow 145. The only downside is I might get a mud splash right on the center of my rear, in the cut-out? :oops:
Scott
PostPosted: Sat Dec 22, 2012 4:44 pm
The main difference is that MTB frame toptubes are about 50-70mm longer, whereas on a road bike, the drop bars add additional reach to the toptube and stem. MTB riders tend to run a shorter stem and more upright postion too for better control at lower speeds and the need to get low'n'aero is less important. Choice of saddle is down to rider preference, but MTB saddles tend to take more of a beating - particularly on a hardtail, as well as coping with the occassional 'off'
Just ride
PostPosted: Sat Dec 22, 2012 8:02 pm
For me, the relationship between my seat and the center of the bottom bracket is exactly the same. On road bikes, I am very flexible and generally run 110 stem with zero slope and no spacers or one very small one. On comparable size MTB, I generally run 80-100 stem with around 15 mm spacers under and a stem with slight upward slope. Also, the seats that I like on road bikes, I hate on MTB. Most MTB seats have flatter fatter rear section since you sit more back on your sit bones.
For certain parts stiffer is more important than lighter.
PostPosted: Mon Dec 24, 2012 4:09 am
My overall reach on my XC Race bike is 40mm shorter than my road bike. Which is fairly typical to what I have seen with others. Mountain bike fit in a more rec or all mountain style is much shorter and more up right and a lot to personal choice. I don't seem may Pro XC bike with high front higher than the seat.
PostPosted: Mon Dec 24, 2012 3:13 pm
Oh yea, the other part of fit-drop. My road bikes the bars are way below the seat (I am very limber) and on my MTB the bars are almost up to seat level, just slightly below. You are just going to have to buy a mountain bike, set the BB to seat distance from your road bike and experiment with all the other perameters including the front-rear orientation of the seat with respect to the BB. The distance BB to seat will be the one constant.
PostPosted: Mon Dec 24, 2012 4:57 pm
I run a pretty similar position as my road bike. I use a 110mm -17 degree stem sitting on the top cap. For my it feels soo much better to be stretched out and having my handlebars a bit lower. I can't stand a short stem/wide bars combo
PostPosted: Mon Dec 24, 2012 11:57 pm
Thank you for the feedback, everyone. Good to know saddle height and setback are similar. I'll have to play around with stack and reach.
Scott
PostPosted: Tue Dec 25, 2012 4:45 pm
I am in a similar road/MTB community. I run exactly the same position as my road/'cross bikes (in fact, I am running drop bars on my MTB, too).
There are no new unread posts for this topic. Attachment(s) Bike fitting on Colnago v1-r
pdiomidis
41
2474
Wed Dec 28, 2016 5:21 pm
Fiery View the latest post
There are no new unread posts for this topic. bike fitting and suggestions help
bigpab
Sun Jan 22, 2017 11:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. VTT / Mountain bike routes in Provence?
bikewithnoname
Mon Jun 20, 2016 4:38 pm
bikewithnoname View the latest post
There are no new unread posts for this topic. 2013 TCR SL4 any good as a 'fitting test bike' ...?
in Training
diegogarcia
Wed Apr 13, 2016 10:22 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Bike fitting in wind tunnel for free (USA only)
benrosa
16
1516
Fri Nov 11, 2016 12:28 pm
benrosa View the latest post
Users browsing this forum: Baidu [Spider] and 11 guests
