Post new topic Reply to topic  [ 12 posts ]
PostPosted: Mon Nov 26, 2012 8:13 pm
I did a search, and I saw no one discussed if these rotors work. Has anyone tried them? They are pretty cheap from eBay at about $22.
Scott Spark LTD 8.40kg
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Mon Nov 26, 2012 8:50 pm
Never tried them but I race XC with these, work superb and are a great price and light.
http://www.xcracer.com/shop/viewproduct ... ductid=176
"I could have done this job myself in five minutes, but as things turned out I had to spend two days trying to find out why it had taken someone else three weeks to do it wrong."
PostPosted: Mon Nov 26, 2012 9:55 pm
http://www.xcracer.com/shop/viewproduct ... ductid=176" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thanks. I've seen those on eBay. I wondered about those.
Do you use 140mm? Do you need an adaptor?
Giant NRS (Retired)
PostPosted: Mon Nov 26, 2012 10:35 pm
No 160 mm, front and rear (sorry wrong link). Run them with the latest XTR brakes, very good indeed.
Previously ran the XTR brakes with Hope floaters and the XTR ice tech rotors that came with the brakes. Both previous rotors were a lot heavier, no noticable performance difference (power and modulation) with the KCNC rotors once they had a few hours of riding on them.
PostPosted: Tue Nov 27, 2012 10:33 pm
Location: At the bottom of the barrel & starting to dig
I use the Ashimas on my cross bikes, they seem to work pretty well even when on the road and braking from speeds of 35-40mph on descents.
PostPosted: Fri Nov 30, 2012 11:03 am
google for Ashima - the older model with the arms pointing the other way had a couple of failures - was posted n this forum too - so as long as you fit them the correct way round you ought to be fine, but stil is a bit off putting.
rotors with huge chunks missing, such as the KCNC razor that I have (160 and 140) can cause fork judder and I find are not a effective as discs with more metal in the braking surface e.g. hope SAW.
PostPosted: Sat Dec 01, 2012 12:57 am
I just ordered the Ai2 rotors to replace my third set of Airotors. The latter have been good for me -- light, excellent stopping power and no squealing. I use 160mm F/R and race XC and endurance events.
One thing I noticed after removing my latest set of Airotors -- they wore in a concave pattern, with the brake pad rounded in the middle and the rotor profile wearing in kind of an hourglass shape. Never happened on my other sets of rotors and the wear pattern couldn't be healthy (the rotors are really thin in the middle of the wear track).
Will try to report on the Ai2 rotors after I have some miles on them...
PostPosted: Sat Dec 01, 2012 12:07 pm
I suppose if you think about it, and this is my take on it so could be wrong, since there is less metal in the centre section, this is worn more and as it becomes thinner, the pad itself bends to where it even further.
i presume we're talking about this:
PostPosted: Sat Dec 01, 2012 12:14 pm
I am using promax which a slightly lighter than those and cheaper, similar to these:
they look like they is more metal in the centre so should not wear like you descibe.
http://www.ebay.co.uk/itm/PROMAX-160mm- ... 3a7c1e4b71
PostPosted: Sun Dec 02, 2012 11:46 pm
I have been using them for about 4 months now with xtr race brakes. They work very well and are very light (obviously.) I have never experienced any fork shudder or brake fade from overheating.
My Bike:
viewtopic.php?f=10&t=110318" onclick="window.open(this.href);return false;
PostPosted: Tue Dec 04, 2012 7:42 am
I have those on my Niner jet 9, XTR trail brakes, never any problem, a little pulsating in low speeds.
Experimental Prototype
PostPosted: Tue Dec 04, 2012 7:02 pm
http://www.ebay.co.uk/itm/PROMAX-160mm- ... 3a7c1e4b71" onclick="window.open(this.href);return false;
The promax 160mm is slightly lighter than the Ai2 in 180mm :wink:
Users browsing this forum: No registered users and 15 guests
There are no new unread posts for this topic. Anyone using Ashima PCB?
in MTB
fastvegan
Sat Jan 12, 2013 11:54 pm
pritchet74 View the latest post
There are no new unread posts for this topic. Opinions on New Build
audiophilitis
21
735
Tue Mar 05, 2013 1:37 am
audiophilitis View the latest post
There are no new unread posts for this topic. Superfeet yellow opinions
MaxDaddy
11
755
Wed Jan 16, 2013 3:46 pm
spytech View the latest post
There are no new unread posts for this topic. Vittoria Corsa Evo SC opinions
wassertreter
Fri Jul 06, 2012 11:18 am
fdegrove View the latest post
There are no new unread posts for this topic. Colour coding opinions?
alexh
16
450
Tue Apr 16, 2013 12:30 am
alexh View the latest post
It is currently Sat May 25, 2013 5:25 pm
