It is currently Sun Jul 23, 2017 5:58 am
PostPosted: Sun Nov 25, 2012 6:20 pm
I guess this must have been asked before, but I couldn't find it. What's the difference between organic pads and ceramic pads? which one is better? which one makes less noise? what about the kevlar pads, how do they perform? any link explaining differences in disc brakepads compounds would be great.
PostPosted: Sun Nov 25, 2012 10:37 pm
Ceramic?
3 Main types of pads, Organic, sintered and Kevlar.
Organic pads are a matrix of a paste with imbedded organic fibres, they have good bite form cold and the performance doesn't drop off too steply with temperature, howver wear rate in muddy/sandy cnditions can be horrendous
Sintered are a powdered metal mixture which is heated enough for the lower melting point metals to soften and bind it all together, they don't have quite the bite of Organic and performance can drop off tragically at high temperatures but wear rates are better in adve
Kevlar are similar to orgaic but with Aramid fibres in the mix which reduce wear.
You can also get organic pads with sintered metal elements in the mix.
PostPosted: Tue Dec 04, 2012 9:08 pm
These are supposed to be ceramic, that's why I asked. Are these the same ones as the so called "organic"?
http://discobrakes.com/?s=0&t=0&c=14&p=125&
http://discobrakes.com/?s=0&t=0&c=14&p=126&
I´m currently running sinterized pads with alloy backed support, which are really light, but performance it's not good enough in very long descents. I run them on hygia slp carbon discbrakes, with 79g 160m rotors.
I think the ceramic or the organic pads will improve the braking performance, and I want them just for very dry weather...
PostPosted: Tue Dec 04, 2012 11:33 pm
TheRookie wrote:
Ceramic?
Thanks for the help
PostPosted: Wed Dec 05, 2012 12:31 pm
"These soft organic ceramic fiber"
Organic....
PostPosted: Sat Dec 08, 2012 1:08 am
ok, then please, explain me what is the difference between these two, cause one is organic and the other is ceramic. which are the differences?
http://www.bike-discount.de/shop/k610/a ... ramic.html
http://www.bike-discount.de/shop/k610/a ... ganic.html
PostPosted: Sun Dec 09, 2012 3:34 pm
Different fibres in the matrix, get 10 different organics and you'll like as not get 10 different fibres, most will use different fibres within the same pad, some use sintered flakes, some use aramid (Kevlar) fibres.....
PostPosted: Sun Dec 09, 2012 5:24 pm
I appreciate your answers and help, but I just want to know the differences in performace and behaviour between "organic" and "ceramic" disc brake pads.
I already know that the composition is different, that is way too obvious. I want to know which ones make less noise, which ones are better for long descents, which ones are better for dry, and which are better for wet, etc... If there is anybody there who knows this please tell me, otherwise i will follow discobrakes advise and get the expensive ceramic pads.
There are no new unread posts for this topic. Brakepads for Vision Metron
in Everything wheels
Kurets
Fri May 05, 2017 1:50 am
NiFTY View the latest post
There are no new unread posts for this topic. Fuji SL 1.1 Disc or Cannondale Synapse Hi Mod Disc or any other Disc Frame under 2000 dollars
vanmatthew
Fri Nov 18, 2016 9:34 pm
mpulsiv View the latest post
There are no new unread posts for this topic. How will the introduction of Hydraulic Disc Brakes impact value of non-disc brake bikes within the next 5 years?
JunkyCollegeBiker18
32
4073
Thu Dec 01, 2016 10:39 pm
AJS914 View the latest post
There are no new unread posts for this topic. Roval CLX50 disc or Dt Swiss ERC 1100 Dicut disc
Y26
Thu Mar 16, 2017 8:55 am
Delorre View the latest post
There are no new unread posts for this topic. CAAD12 Disc Fram + New Campy Disc = Compatible?
NewYorkNick
19
1414
Sat May 13, 2017 8:17 pm
NewYorkNick View the latest post
Users browsing this forum: No registered users and 6 guests
