Post new topic Reply to topic  [ 4 posts ]
 Post subject: xtr m970 vs m980 e type
PostPosted: Thu Nov 22, 2012 10:14 pm
anyne kinow difference? from what I can gather from thee next, m970 is 3 chainring but with alloy cage; wheraes 980 is the same but stell cage? anyone confirm that?
m970 = 130 g, m980 = 142 g (due to alloy cage no doubt - somehow an alloy cage to rub against a chain does not seem like a good long term proposition).
hmmm ... seems both have alloy cages 970 is 9sp and 980 is 10 spd as far as i can tell :noidea:
PostPosted: Fri Nov 23, 2012 1:05 am
I don't think either have an aluminum cage. Probably not since the 950- series.
The m980 is 10speed. The m970 is 9speed. Because the m980 is 10speed, it is designed for a 42t outer ring, the 9speed is based around a 44t ring.
PostPosted: Fri Nov 23, 2012 10:26 am
brilliant info ..... I guess I should have twigged after trying to use a 10 spd SLX front mech. :thumbup:
so it is m970 I need.
re: spec.
Shimano XTR Front Mech E-Type 9sp M970 Specifications :
Series: XTR
Model No. FD-M970-E
Rear Speeds: 9
Front SIS :Yes
Chain Ring : Triple/Double
Top Swing Link : Yes
E-type BB Mount : Aluminum
BB Plate :Aluminum
Outer Link Material/Finish : Steel/Painted
Inner Link Material/Finish : Aluminum/Painted
Chain Guide Material/Finish : Aluminum/ Nickel Plated
PostPosted: Fri Nov 23, 2012 10:34 am
re: spec.
Series: XTR
Model No. FD-M970-E
Rear Speeds: 9
Front SIS :Yes
BB Plate :Aluminum
Users browsing this forum: No registered users and 5 guests
There are no new unread posts for this topic. Light Shimano XTR M980 Jockey Wheels?
in MTB
DanW
Thu Feb 14, 2013 12:20 pm
DanW View the latest post
There are no new unread posts for this topic. Correct front derailleur for FC-M980 double?
in MTB
hjb1000
Tue Feb 26, 2013 8:33 am
bm0p700f View the latest post
There are no new unread posts for this topic. Crankset - light alternative to XTR M980/M985?
in MTB
RedRacer
Mon May 06, 2013 4:10 am
UpFromOne View the latest post
There are no new unread posts for this topic. Shimano xtr m980 shifters- dura ace front-rear derailleur.
in Cyclocross / Touring
Erhar
Wed May 22, 2013 9:31 pm
maddog 2 View the latest post
There are no new unread posts for this topic. What type of headset do I need?
chiltonp
Wed Jul 11, 2012 10:17 pm
rockdude View the latest post
cron
It is currently Thu May 23, 2013 12:17 am
