Post new topic Reply to topic  [ 7 posts ]
PostPosted: Wed Nov 14, 2012 11:55 am
I've done a few more small jobs which drop the weight a little more, I'll update shortly.
Those jobs got me thinking though...
I usually ride on road, singletrack and general X-country so I rarley heat up my 160mm rear rotor which makes me think that a 140mm rotor would be totally fine.
So is it possible? Would I need to downsize my caliper, shift the caliper rearwards by removing spacers, change pads?
I've uploaded a pic so you can take a close look, I've no idea so any help would be much appreciated.
[url][url=http://www.flickr.com/photos/79798036@N02/8184700949/]Image[/url]
DSC09774 by Chuck-light, on Flickr[/url]
[url][url=http://www.flickr.com/photos/79798036@N02/8184741126/]Image[/url]
DSC09776 by Chuck-light, on Flickr[/url]
(excuse the muck, only just got in)
Cheers guys
Bike: 2012 Boardman HT Pro MTB - 21.949lbs / 9.956kg (for now...)
PostPosted: Wed Nov 14, 2012 12:39 pm
It's not happening, you have a post mount frame mount and it is set to make it suite a 160mm disc with no adaptor, so 160mm disc it is.
PostPosted: Wed Nov 14, 2012 5:01 pm
^^^^ nope as he said - not unless you modify the frame.
PostPosted: Sun Nov 18, 2012 10:07 pm
if you elect to trim down the post mounts, by 5mm, and do not use washers between the caliper and the post, you can drop the caliper by 10mm total, allowing for a 140 rotor.
The downside is not that there wouldn't be enough threading in the post (they are tapped quite deep enough), but once you trim the post, you'd need a 160-to-180 post spacer (10mm) just to go back to a 160 rotor w/ std. washers.
Not to mention losing a bit of caliper adjustability with no conical washers.
I have done this with noissues whatsoever, but never trimmed the post by a full 10mm just to save the caliper washers.
PostPosted: Mon Nov 19, 2012 6:55 am
Those posts won't trim by 10mm, yes you could trim by 5mm and lose the washers, but then you'd be stuck with Avid callipers forever....
PostPosted: Mon Nov 19, 2012 8:14 am
Just don't do it. I'm all for tuning, but this isn't happening.
The weight saved, for once, will not be worth the list of negatives as a result.
BMC SLC01
Visiting South West Australia? Visit Crank n' Cycles!
PostPosted: Mon Nov 19, 2012 12:48 pm
Too right, the thought of never being able to junk the Avid brakes is terrible! :D
Users browsing this forum: No registered users and 22 guests
There are no new unread posts for this topic. Scrub Raceday Rotors (Black) 160mm & 140mm
Johnny_Yutah
Wed Mar 06, 2013 4:38 pm
Johnny_Yutah View the latest post
There are no new unread posts for this topic. Attachment(s) Formula 6-bolt rotor - 160mm
krzysiekmz
Wed Feb 13, 2013 12:01 am
krzysiekmz View the latest post
There are no new unread posts for this topic. Attachment(s) Formula floating 6-bolt rotor - 160mm
krzysiekmz
Mon Feb 18, 2013 6:57 pm
There are no new unread posts for this topic. Attachment(s) My Boardman AiR/9.8 with Rotor Power Crank
Mario Jr.
Tue Apr 02, 2013 8:32 am
Giant DK View the latest post
There are no new unread posts for this topic. Boardman 9.8 SLR - 6.40kgs large!
Leviathan
Sun May 19, 2013 8:06 pm
paradawt View the latest post
It is currently Mon May 20, 2013 8:00 pm
