Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Nov 06, 2012 11:23 pm
... yet another SCRAM XX related post
Will the SRAM chainrings that fit on the spider fit onto a SRAM crank? (the rings do look very similar to my untrained eye)
The spider I refer to is this:
And SRAM one piece crank I refer to is:
PostPosted: Tue Nov 06, 2012 11:36 pm
No, can't change spider on a XX. Just X.0 and X.9, maybe also X.7
/jonas l
PostPosted: Tue Nov 06, 2012 11:57 pm
sorry, not sure my question was clear - I am asking if the rings taken off the spider will fit onto the crank? (spider is thrown away)
surely as a manufacturer you would design spider and crank to take one type of ring instead of designing 2 different types of ring???? so I am hoiping somebody has tried this andthe answer being yes :)
PostPosted: Wed Nov 07, 2012 12:39 am
Yes!
As long as the rings have the same BCD they will fit. As on the pictures you show, both rings are XX (120/80 BCD) so they will fit on that specialized spider as well as they will fit on a XX cranks.
PostPosted: Wed Nov 07, 2012 2:55 am
Just be careful with the 'chain drop' pin on the big ring. There are 3 lengths for BB30, GXP and Cannondale cranks.
Start flat out ... then pick the pace up halfway
PostPosted: Mon Nov 12, 2012 5:39 am
If both rings (inner an outer) have the same BCD (120/80), you can put in XX crankset.
Users browsing this forum: Exabot [Bot] and 7 guests
There are no new unread posts for this topic. WTT: SRM Hollowgram standard spider for compact spider
in Wanted
laleme
Sat Apr 20, 2013 3:04 pm
laleme View the latest post
There are no new unread posts for this topic. Attachment(s) Sram XX1 Spider for Cannondale Hollowgram
dwaharvey
Tue Apr 16, 2013 7:43 pm
dwaharvey View the latest post
There are no new unread posts for this topic. SiSL2 Crank Arms, Leonardi Spider, XX1 Ring, on Scalpel 29?
in MTB
Singletrackmind
11
1082
Tue Mar 05, 2013 11:10 pm
ms6073 View the latest post
There are no new unread posts for this topic. XX1 Spider for Hollowgram Released
in MTB
skiandbikecmh
Fri Mar 01, 2013 3:50 pm
There are no new unread posts for this topic. Hollowgram SI SL 130BCD Spider
in Wanted
doomith
Fri Apr 26, 2013 11:02 am
doomith View the latest post
It is currently Thu May 23, 2013 9:09 am
