Post new topic Reply to topic  [ 15 posts ]
PostPosted: Tue Nov 06, 2012 7:24 am
handlebar weenies: anyone know of any flat bars, 600mm wide, that have NO backsweep? I see alot of flat bars out there, but they all have varying degrees of sweep to them.
I started with a 6 degree bar, now on Easton 3 degree backsweep, and needing a pencil-straight bar.
PostPosted: Tue Nov 06, 2012 7:42 am
Well a few guys around where I live went to one of the aeroplane companies in town and got a 22.2mm titanium tube and then cut it to what ever length and just run a shim to 25.4. seems to work well
PostPosted: Tue Nov 06, 2012 8:30 am
thx, that's a good idea.
Ti Cycles used to be here in Seattle, now in Portland OR but Dave still does bars of all kinds.
What about a 7/8" carbon tube? Would I be risking my life to try this kind of bar stock:
http://www.ebay.com/itm/22-2-X-20-X-100 ... 337d7656c4
(It's got .050" wall thickness)
PostPosted: Tue Nov 06, 2012 12:50 pm
1.25mm is too thin for bars.....
The 'Dildo bars' are dead straight but not at all WW.
PostPosted: Tue Nov 06, 2012 5:34 pm
Yeah, kinda knew that, but thanks for the reality check!
I have a 130g bar now, so I don't really want to go over that.
Would have thought that some manufacturer offers a carbon fiber 'dildo' bar...Oh hey, maybe I should look in a sexshop?? :lol:
PostPosted: Wed Nov 07, 2012 7:14 am
1.6mm wall....
http://www.carbonology.com/25m-woven-ca ... p-361.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;.
Or Giant CRC is claimed to be straight
http://www.triplebuttedcycling.co.uk/gi ... mm-4-p.asp" onclick="window.open(this.href);return false;
PostPosted: Sat Nov 10, 2012 4:54 am
BINGO on the Giant! Thanks Rookie!
PostPosted: Sat Nov 10, 2012 10:11 pm
No worries, just messed around with search terms (use Yahoo, less dodgy cemmercial hits which you don't want than Google!).....
PostPosted: Wed Nov 14, 2012 8:24 am
That Giant straight bar is from a UK dealer, but no response to my email (i'm on west coast usa).
Looked on eBay, apparently the chinese think that a "straight" bar means flat with sweepback. Lost in translation :roll:
Any other suggestions?
PostPosted: Wed Nov 14, 2012 12:07 pm
Can try and help youm sourcing from UK dealer.
Try CF specialists for straight tube, but you'll either have 22.2mm which means shims or 25.4 and be unable to fit controls.....
PostPosted: Tue Nov 20, 2012 7:30 am
I actually just received a 24" straight 7/8" carbon tube from dragonplate. 97g + it seems more than stiff and strong enough.
And it seems from poking around the interwebs that there are no light wieght 110 stems with a 22.2 bar mount.
So either use shims with a 25.4 stem, or i might ask Calfee or someone similar to fuse/wrap the 7/8 bar onto a lightweight stem and create a monocoque.
PostPosted: Mon Jan 14, 2013 9:03 pm
Just took delivery of that Giant "straight" bar from UK. Guess what? It's NOT straight, it has like 8 degrees of backsweep.
Looks like I keep using my 7/8" OD carbon tube w/.0625 wall that I found. That's been working fine so far.
PostPosted: Tue Jan 15, 2013 12:52 am
I would be wary of using a plain piece of carbon tubing as a handlebar.
Not meant to bear load in that manner. Ask a carbon builder.
Imagine clamping a carbon tube in a repair stand very tightly, then working both ends.
PostPosted: Wed Jan 16, 2013 6:13 am
yes, i'm cognizant of that. my issue is that any backsweep causes wrist pain. i know,not normal but it is what it is and only a straight bar works for me. so far so good, but yes it is not a dedicated handlebar.
I emailed TBC to suggest they might want to use a different word than "straight" to describe their backswept bar.
PostPosted: Wed Jan 16, 2013 2:23 pm
Absolutely, I'd also be asking for some compensation to cover what you'll be out of pocket in selling it on.
As for the CF bar, doesn't matter what it is designed for, it's either strong enough or not!
Users browsing this forum: No registered users and 9 guests
There are no new unread posts for this topic. DT 240 S Straight pull
GT56
Wed Oct 24, 2012 1:28 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Trade - Straight Post
in Wanted
DamoRider
Tue Apr 09, 2013 12:36 pm
DamoRider View the latest post
There are no new unread posts for this topic. Light Clip-On Bars for 3T Ergonova Bars.
CerveloBert
Mon Aug 13, 2012 4:24 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Attachment(s) Measuring straight pull spokes?
Rumsas
Thu Aug 23, 2012 11:14 am
Rumsas View the latest post
There are no new unread posts for this topic. Experience with C-4 straight pull front hub
Anders
Wed Jan 09, 2013 2:54 am
boneman View the latest post
It is currently Thu May 23, 2013 6:51 pm
