Post new topic Reply to topic  [ 42 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Mon Oct 29, 2012 6:46 am
Kevin,
Valid suggestion but I don't like longer bolts as it's not 'clean' also they are heavier so may well offset the deficit of using the inners!
Stephen, perhaps you should offer inner (thinner) and outer bash type rings in CF individually!
PostPosted: Mon Oct 29, 2012 3:02 pm
I'm going a similar path (Using a bunch of old parts to build an XC bike).
I'm opting for an E13 ring and an XCX guide. I like the idea of dual guide rings though, and time will tell how reliable a guide is.
BMC SLC01
Visiting South West Australia? Visit Crank n' Cycles!
PostPosted: Mon Oct 29, 2012 4:16 pm
I run 1x10 Shimano XT 980 setup with SRAM 1070 12-36
- RF Turbine 180 with RF SS 302t ring
- Shaman Racing ChainGuide
- KMC X10 SL chain - shortened as much as possible on 32-36 gear
Never had any problem at all.. even when I tried setup without chainguide...
Not exactly pure Weightweenie.... but still crazy enought to hunt every possible gram (used to be, but still like reasonably light bikes :-))
- LITESPEED Obed
- STORCK Scenario Team
PostPosted: Mon Oct 29, 2012 4:17 pm
Well I have an E13 ring on the way, already have an outer bash, just deciding whether to buy a CF from Stephen, a raidium or make my own.....as soon as I've tried it I'll report back!
On my commuter (1x9) without a chainguide the chain kept coming off on shifts......
PostPosted: Mon Oct 29, 2012 5:54 pm
We can do them easily. 2mm inner and 3 to 4mm outer would seem about right. We wouldn't have a 'standard' set as the diameters would all need to be fairly custom depending on the size of the chainring.
PostPosted: Mon Oct 29, 2012 7:33 pm
no fence..but double bash our single bash is IMO ugly... chainguide such as MRP is much elegant...
- LITESPEED Obed
PostPosted: Mon Oct 29, 2012 7:35 pm
but Hope chainguide with outer bash ring would be kickass :D
- LITESPEED Obed
PostPosted: Mon Oct 29, 2012 7:49 pm
That depends very muh on where you ride really though! I'd prefer to not run a bash, but would prefer to rather than keep damaging chainwheels!
PostPosted: Tue Oct 30, 2012 12:31 am
I'm not sure how a downhill type chain guide is more elegant than a bash guard, personally I think a bash guard is far more elegant.
The Hope chainring with built in guide is a really nice piece of kit. No idea on price though?
Last edited by stephen@fibre-lyte on Tue Oct 30, 2012 4:20 pm, edited 1 time in total.
PostPosted: Tue Oct 30, 2012 2:55 am
I think it's going to hit for somewhere between $80-$100. I'm going to guess weights will be around 70g too, going by the amount of metal (2x chainring. Rough estimate.)
Hope make fantastic products, and this might be a great alternative to a chainguide if it can be used with a jumpstop or similar. However that does not solve backpedal shifts.
If a secure setup could be accomplished with a minimal chainguide and single ring, this is a close weight battle. Jumpstop/inner fence + IBR would be damn close to a single ring + XC guide.
BMC SLC01
PostPosted: Tue Oct 30, 2012 9:04 am
A light'ish' ally bash is about 100g, a decent 32t circa 30-35g, so I'd guess at 120-150g for it.
PostPosted: Tue Oct 30, 2012 10:24 am
Hope say from 62g. That is genuinely impressive.
http://www.hopetech.com/page.aspx?itemi ... cification
BMC SLC01
PostPosted: Tue Oct 30, 2012 1:41 pm
That is very impresive indeed......£70 (RRP) is a bit expensive compared to a conventional ring and bash (about £45-50) but for a saving of about 60-90g makes it cheap! £63 from CRC.
PostPosted: Tue Oct 30, 2012 4:22 pm
For what you're getting I think £70 is a bargain. Around the same as an XTR chainring isn't it?
PostPosted: Tue Oct 30, 2012 10:27 pm
Combined with a CF inner guide ring, it would be super lightweight 1x option!
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: No registered users and 6 guests
There are no new unread posts for this topic. Gaerne G. Chrono - opinions wanted
martinSL
13
1238
Wed Mar 13, 2013 3:10 pm
Horacio View the latest post
There are no new unread posts for this topic. Recon Idea ?
artray
Sat Aug 11, 2012 8:32 pm
artray View the latest post
There are no new unread posts for this topic. Great idea ...why has no one thought of this
artray
10
1051
Sat Dec 22, 2012 4:27 pm
Geoff View the latest post
There are no new unread posts for this topic. Bolt-On hub on MTB bike-good idea??
in MTB
bikemaniack
Thu Oct 11, 2012 1:17 pm
bikemaniack View the latest post
There are no new unread posts for this topic. Shimano Powertap wheel idea
PoorCyclist
10
756
Thu Jun 14, 2012 10:29 pm
PoorCyclist View the latest post
It is currently Tue May 21, 2013 12:11 pm
