Post new topic Reply to topic  [ 26 posts ]
Go to page 1, 2  Next
 Post subject: Rotors replaced
PostPosted: Wed Oct 10, 2012 4:48 pm
Replaced my original Shimano rotors with Ashima AI2 (Apperently the lightest rotors on earth)
Original Shimano rotors
New Ashima AI2 Rotors
Braking feels a bit soft, but that's maybe because they're new.
But they look very very nice :)
Anyone else experience with these rotors?
PS I have no idea how accurate my kitchen scale is :P
Cannondale Bad Boy 4 (2012) Original weight minus 1541 Gram
 Post subject: Re: Rotors replaced
PostPosted: Wed Oct 10, 2012 7:37 pm
I have been using them on my mountain bike for the past summer. They are not the lightest on earth, maybe the lightest steel rotors on earth, but certainly scrub alum are lighter. I love how light they are and they work very well.
My Bike:
viewtopic.php?f=10&t=110318" onclick="window.open(this.href);return false;
PostPosted: Wed Oct 10, 2012 8:13 pm
Seems like theres a bit of coating on the rotors.
Just took the bike out for a very short road trip (5km)
In the beginning, the braking was very soft, with no feel at all.
When I got home, braking was somewhat better.
Hope it will improve, cause I never had this issue with the original Shimano rotors.
PostPosted: Wed Oct 10, 2012 9:14 pm
It is perfectly normal for brand new rotors to not stop as well as used ones, simply because they still have the factory glaze on them. Whenever I get new rotors, I always make a point of sterilizing them with alcohol and then sintering them. That should help to clean them off a bit.
Just keep on riding yours though. With time, the stopping will get more powerful.
Nice choice on a rotor though. They sure do look pretty sweet!
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Thu Oct 11, 2012 7:56 am
I always clean new rotors with ipa and a white cloth prior to fitting.
You can always see grease (hence using the white cloth) so you may have lightly contaminated the pads.
Personally, I'd wipe the rotors with alcohol and remove the top layer of pad material with sandpaper.
PostPosted: Thu Oct 11, 2012 9:23 am
You need to bed any new disc/pad combo in, braking is actually pad against pad material deposited as a (very) thin layer on the disc, Shimano gives a simple procedure for this involving 20 'stops' at 'moderate' braking from about 15mph to not quite a stop - simples.
PostPosted: Thu Oct 11, 2012 10:14 am
Going to do a road run of 40k tonight.
Will gently abuse them :P to see if braking gets better
PostPosted: Thu Oct 11, 2012 12:40 pm
No need to abuse, but repeated moderate braking to get some (but not too much) temperature in them is what is needed, fortunately minimalist discs like that (I run Alligators) warm up more quickly!
PostPosted: Thu Oct 11, 2012 7:23 pm
Got a strange problem.
Rear rotor is just perfect.
But the front doesn't brake as hard as the original Shimano's (BR-M446) do.
If I lean to the right on the bike, I can hear one of the pads grinding against the disc.
When straight on the bike or leaning to the left there's no problem.
Sound familiar to someone?
Will change front and rear tomorrow and see if something changes.
PostPosted: Thu Oct 11, 2012 8:17 pm
That shouldn't affect braking at all.....which sounds like pad contamination, you did degrease the new discs didn't you?
PostPosted: Thu Oct 11, 2012 8:45 pm
Nope :shock:
But that doesn't explain the pad grinding the rotor when the bike is tilted.....
PostPosted: Fri Oct 12, 2012 12:42 am
Is the front skewer tightened adequately? This could be the issue. The caliper may not be completely centered over the rotor too. They caliper may be sitting too far outboard which could be explaining the rubbing.
PostPosted: Fri Oct 12, 2012 5:48 am
Skewer is OK, If the bike is picked up, the wheel can spin freely without the pads rubbing against the rotor.
Problem only occurs when I'm riding and I lean to the right.
Will try to shift the caliper today.
PostPosted: Fri Oct 12, 2012 7:17 am
It will be the skewer. What are you using?
Sometimes with the lightweight stuff such as kcnc, the shorter lever lacks ....ur leverage :D
No biggie just another turn should do the trick.
As per my previous post, did you clean the rotors before fitting them?
PostPosted: Fri Oct 12, 2012 7:40 am
The skewers are the original Shimanos.
Never had an issue with the original rotors. So can't imagine that being the problem, but I will try giving them another turn.
For the rotors I was stupid enough not to clean them :oops:
First time I've replaced rotors, so apperently I have a lot to learn.
Will try to get the top layer off from the pads. Or just buy a new set of pads.
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 13 guests
There are no new unread posts for this topic. SiCCC rotors for road
xrs2
9
735
Sun Mar 24, 2013 4:55 pm
xrs2 View the latest post
There are no new unread posts for this topic. Shimano Disc Rotors
ipenguinking
Sun Mar 03, 2013 6:41 pm
ipenguinking View the latest post
There are no new unread posts for this topic. Avid XX brakes new with rotors
helios
Sat Feb 23, 2013 2:42 am
helios View the latest post
There are no new unread posts for this topic. Experience of Absolute Black rotors?
in MTB
CGT
Thu Oct 25, 2012 1:47 pm
Mattias Hellöre View the latest post
There are no new unread posts for this topic. Formula 2 piece rotors + XTR brakes ??
in MTB
nonamed
Sat May 18, 2013 6:48 pm
TheRookie View the latest post
It is currently Fri May 24, 2013 3:33 pm
