Post new topic Reply to topic  [ 3 posts ]
PostPosted: Fri Jan 17, 2003 5:34 pm
Hi,
does someone use an extralite road stem on a mtb? I have a schmolke handlebar with almost the same diameter(25,7) as the roadstem(26,0).
Ciao
mtbmarcus
 Post subject:
PostPosted: Sun Jan 19, 2003 8:54 pm
well, the roadstem is the same as the mtb stem, the only fact is that maybe the diameter does not fit correctly your bar. the weight is the same. but I don't know if that stem is useful enough for a mtb.... maybe when your not weighing about 220 lbs like me but when your about the half it can handle your weight.
 Post subject:
PostPosted: Sat Jan 25, 2003 7:03 am
extralite have MTB stem, i have the extralite ultralite UL stem weighting 94grams for 100mm length.
as road stem diameter is different from MTB, you might have to use a shim to fit.
otherwise get a proper MTB stem or lose getting a grip on bar.
hope this help.
cheers
Users browsing this forum: No registered users and 10 guests
There are no new unread posts for this topic. Extralite Roadstem UL2 - 120mm 92,1g - 80€
dark_albert
Tue Feb 26, 2013 10:01 pm
dark_albert View the latest post
There are no new unread posts for this topic. Extralite discontinues the longer RoadStem OC
Causidicus
19
1045
Sun Mar 31, 2013 1:27 pm
mythical View the latest post
There are no new unread posts for this topic. Extralite Ultralevers
in Wanted
adidavas
Wed May 01, 2013 8:43 pm
adidavas View the latest post
There are no new unread posts for this topic. Extralite Streeters
Stolichnaya
14
989
Tue Jun 26, 2012 5:30 pm
Stolichnaya View the latest post
There are no new unread posts for this topic. Extralite Ultrastar (2)
Stockie
Mon Jun 18, 2012 9:58 pm
mambocat View the latest post
It is currently Mon May 20, 2013 1:11 am
