Post new topic Reply to topic  [ 8 posts ]
PostPosted: Fri Oct 05, 2012 4:03 pm
Is ti anti sieze grease required for ti bolts on alloy?
Scott Spark LTD 8.40kg
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Fri Oct 05, 2012 6:52 pm
no grease, just dry threads and never had a problem in 12 years
PostPosted: Fri Oct 05, 2012 8:29 pm
For stem bolts I dont bother but if its a larger Ti bolt under high torque into alloy then I do.
galvanic corrosion can set in effectively welding the surfaces together. Don't worry, this is only an issue with bottom brackets which stay put for many months/ years.
PostPosted: Sat Oct 06, 2012 5:22 pm
My Ti rotor bolts galvanically welded themselves into my hubs, I used copperslip.
Cant get one of the bolts out. :oops:
"I could have done this job myself in five minutes, but as things turned out I had to spend two days trying to find out why it had taken someone else three weeks to do it wrong."
PostPosted: Sat Oct 06, 2012 10:42 pm
Yes, it is. Ignore the people trying to save a couple of bucks by doing things incorrectly.
PostPosted: Mon Oct 08, 2012 6:12 pm
Yes it is required and not just on the threads, particular attention should be given to the underside of the bolt head where it mates against the alloy surface.
PostPosted: Tue Oct 09, 2012 9:26 am
Administrator
Cheap insurance. I use it on all bolts.
PostPosted: Tue Oct 09, 2012 12:44 pm
Definitely yes... alu and ti together can also result in creaking, the anti sieze/slip will stop that.
Users browsing this forum: Google [Bot] and 9 guests
There are no new unread posts for this topic. Groupset mounting bolts... to grease, or not to grease?
Stats
Tue Dec 25, 2012 12:09 am
yourdaguy View the latest post
There are no new unread posts for this topic. alloy bolts sram red 2013
c90sx
Fri Feb 01, 2013 1:26 pm
stevec1975 View the latest post
There are no new unread posts for this topic. +/- 4 deg alloy stem?
AllAboutTheEngine
Thu Dec 13, 2012 9:37 pm
NGMN View the latest post
There are no new unread posts for this topic. Extralite stem bolts
highwater
20
687
Thu Jan 17, 2013 2:10 pm
mellowJohnny View the latest post
There are no new unread posts for this topic. ZIPP SL Stem Torq bolts
digitalnorbs
Mon Jun 25, 2012 3:02 pm
digitalnorbs View the latest post
It is currently Sun May 19, 2013 6:51 am
