Post new topic Reply to topic  [ 8 posts ]
 Post subject: Speedhub
PostPosted: Sun Jan 18, 2004 11:38 am
http://www.rohloff.de/index.php?p=TECHNIK/SPEEDHUB
anyone here know anything on this hub, first hand? pretty heavy at 1700 - 1825 grams. is the hub considered rotating weight?
 Post subject:
PostPosted: Sun Jan 18, 2004 1:59 pm
O2 Bikers (Belgian mtb magazine) once did a test with this hub but that's a pretty long time ago. I do not have the issue here with me but i remeber they said the hub has a lot of internal friction and yes the weight is rotational weight i guess. Advantage is that the chain reaches a higher mileage.
Cheers
Ivan
 Post subject:
PostPosted: Sun Jan 18, 2004 6:48 pm
Site Admin
There are a lot locals around here who ride a Rohloff.
The planetary gearing needs a relatively long running-in time (at least 1000 km), but afterwards internal friction is nearly on par with normal derailleur shifting.
It's also much more resistant against mud than a normal derailleur setup.
Rotational weight is of course higher, so it's not a choice for XC racers.
Compared to a normal wheel you also feel the additional weight on the rear.
But if you ride rougher, do many miles or want a low-maintenance setup it's really unbeatable:
no more shifting problems, no more adjusting and a chain usually lasts about 4000 km.
The only regular maintenance Rohloff recommends is an oil change every 5000 km or per year.
 Post subject:
PostPosted: Mon Jan 19, 2004 8:27 am
i was thinking of buying a 24" cruiser bike with this hub. they usually dont have gears, so i dont know if this hub would fit on. but its a good idea.
here is the frame i was thinking of using with the speed hub: http://www.danscomp.com/cgi-bin/hazel.c ... tem=221099
 Post subject: hubs
PostPosted: Mon Jan 19, 2004 11:42 am
Rotational weight isn't really an issue with hubs owing to the low diameter in question.
Heavy is still heavy but won't have the same multiplied effect as a heavy rim or tyre.
.....but it still has to work!
 Post subject:
PostPosted: Mon Jan 19, 2004 12:56 pm
ahh, the answer i was looking for. i hope they make this hub for bmx cruiser bikes. anyone know?
 Post subject:
PostPosted: Mon Jan 19, 2004 1:03 pm
Administrator
their with is 135 mm. does that fit in the bike?
Follow me on twitter. I try to be interesting ;)
On Facebook!
 Post subject:
PostPosted: Mon Jan 19, 2004 1:14 pm
i would have to find out, but standard bike co. does custom frames, so i would see if they can do something for me. this is very intresting. a little heavy but intresting.
Users browsing this forum: Exabot [Bot] and 10 guests
It is currently Sat May 18, 2013 1:54 pm
