Post new topic Reply to topic  [ 11 posts ]
 Post subject: Upgrade Time
PostPosted: Thu Sep 20, 2012 8:37 am
Hello everyone,
Next year I intend to partake in a six event XC series, Now because there is only six events I was hoping I could just upgrade the components on the bike I already have, 2010 Rockhopper Comp SL, so I have a couple questions.
Is the bike able to take some 650s?
What's the general consensus on best groupo for XC racing?
Reason I don't really want to just buy a whole new bike is well I like this frame a lot, love it actually and I'd rather upgrade it and keep it. I don't know too much about XC racing I just know I like racing and I like rattle about the trails of Scotland so may as well combine the two on top of the road racing.
Thanks for any help
Lee
 Post subject: Re: Upgrade Time
PostPosted: Thu Sep 20, 2012 6:35 pm
Post a component list and total budget for upgrades. We need more info in order to help.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Thu Sep 20, 2012 9:51 pm
Yep that would help.
Frame: Specialized M4 fully manipulated alloy frame, fully butted, ORE Downtube, asymmetrical seat stays, forged dropouts with replaceable derailleur hanger, disc only
Fork: Rock Shox Tora SLite, 80/100mm travel, 1 piece magnesium lower, 32mm Cr-Mo stanchions, alloy steerer, rebound and preload adjust with LO, size-specific spring rates
Front Derailleur: Shimano Deore, 34.9mm clamp, top swing, bottom pull
Rear Derailleur: Shimano RD-M662 SLX Shadow, long cage
Shifters: Shimano SL-M531 Deore trigger
Chainset: Shimano FC-M442, Octalink Spline
Chainrings: 44/32/22 tooth chainrings
Bottom Bracket: Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
Cassette: Shimano HG50, 9-speed, 11-34 tooth range
Chain: KMC X9 with reusable Missing Link
Pedals: Alloy body and cage, 9/16 inch
Front Brake: Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep rotor
Rear Brake: Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep rotor
Brake Levers: Avid Juicy 3 SL
Handlebars: Butted alloy riser bar, 25mm rise, 660mm wide, 8 degree back sweep, 7 degree up sweep
Stem: 3D forged alloy, reverse 4-bolt, 7 degree rise, 31.8mm clamp
Headset: 1-1/8 inch threadless, Campy style semi-cartridge bearings
Grips: Specialized Enduro, dual compound Kraton, no flange, 131mm
Rims: Alex RHD 26 inch, pinned, alloy double wall, eyelets, 28h front and 32h rear
Front Hub: Forged alloy, hi/low flange, sealed cartridge bearing, machined disc mount, 28hole
Rear Hub: Forged alloy, double sealed cartridge bearing, machined disc mount, cassette, QR, 32hole
Spokes: 2mm (14g) stainless
Front Tyre: Specialized Fast Trak LK Control, 26x2.0", 60TPI, tubeless ready aramid bead
Rear Tyre: Specialized Fast Trak LK Control, 26x2.0", 60TPI, tubeless ready aramid bead
Tubes: Schrader valve
Saddle: Specialized Rockhopper XC, Body Geometry, hollow Cr-Mo rails, 143mm width, front and rear bumpers
Seatpost: Alloy two bolt, double butted quill, micro adjust, 30.9mm
Seat Binder: Forged alloy QR, brass washer
Accessories: Chain stay protector, reflectors, clear coat, owners manual
That's the stock run down, only thing that's different is I'm running egg beaters. Budget is about £7-800 over a couple months not wanting the ultimate just upgrades :) and I don't mind buying second hand.
PostPosted: Thu Sep 20, 2012 10:28 pm
I would first recommend a new bike: your Tora fork is the weak point of that bike. Not knocking the rockhopper frames, as they're really nice, but pointing that out.
If you're wanting to upgrade piece by piece, I would start with the fork. Rebas are excellent, and would be a big performance upgrade. Next, a wheelset with some stan's rims would make a huge difference. I have noticed lately seeing crossmax 26 wheelsets being sold for dirt cheap--so that's another option. Tubeless with sealant is crucial for performance and non-flat-ability.
The stem you have is a pig. Seatpost too. Upgrading those is fairly cheap.
The heaviest part of your drivetrain is the crank. I'd look at a decent used crank before the rest of the drivetrain. The older 9speed XT cranks can be had pretty inexpensively. Unless you spend a heap of cash on a 10 speed drivetrain, losses in weight and increases in shifting performance would be pretty minimal. That being said, 9 speed sram stuff is a pretty safe bet to buy used. I'd steer away from buying a used 9 speed shimano drivetrain as they seem to loose performance quicker--i.e. the b adjust and return springs wear out.
further down the list: the juicy 3s are heavy, but pretty reliable and stop well.
To sum up:
fork: 300--beware buying used though
wheels: 300
stem, post: 60, maybe bars if you need something that has a different bend
cranks: 80
PostPosted: Thu Sep 20, 2012 11:01 pm
Thanks that the stuff indeed to know. Kind of want to stick with the frame as tbh I just like it.
I'll look into forks as a matter of urgency. Project commenced.
PostPosted: Fri Sep 21, 2012 1:45 am
I started racing on a bike which is roughly the same spec.
My first upgrade was my fork.
To be honest I wouldnt throw too much money at the bike.
It's a strong reliable everyday build, but it's never going to be a lightweight nimble xc machine without spending the type of money on parts that you could buy a higher spec bike with.
I know because I made that mistake when I was getting into mtb racing.
Deore and SLX is a great start up group.
If you really want to keep the bike- Fork first, then wheels, mainly because the wheels can be easily swapped to a new bike when you decide to upgrade.
Lefty heaven
PostPosted: Fri Sep 21, 2012 5:25 am
Definitely get a lighter fork. The tora is a tank.
Reba, light wheelset, fast rolling xc tires setup tubeless, upgrade cockpit parts to lighter spec, the replace drivetrain with lighter parts as it wears out.
I don't see any problem blowing loads of cash on this bike. At some point, you'll probably realize you want a different frame and then you can build up a new bike using the awesome parts you've amassed.
PostPosted: Fri Sep 21, 2012 12:32 pm
Get a new fork, but keep all the take off stuff and then you can put it back on the bike when/if you finally buy a new one!
Any HT2 crankset/BB would be lighter than Octalink, get the frame faced as well for bearing life (and knocking a couple of g's off!), Juicy's are a bit heavy but upgrading will cost, spesh's stem/seatpost and bars tend to be lardy, getting good used stuff will save a lot of weight for not much money, bolted seatpost clamps are always (near enough) a lot lighter than QR and a used one should be pennies.
Trust the reflectors are off by now!
PostPosted: Sat Sep 22, 2012 10:11 am
Took me all of 5 minutes looking for some parts to realise I can build a whole new bike in time for April pretty darn cheap so that's what I'm going to do and use the Rock in the mean time for training till it breaks.
This is the inspiration for my build...
PostPosted: Sat Sep 22, 2012 11:55 am
Not a bad inspiration. That saddle/seatpost combo costs as much as the total improvements people were recommending for your Rockhopper, but it appears to be a VERY nice build.
PostPosted: Sun Sep 23, 2012 1:07 am
Yeah sadly I mean just an epic on 650s haha.
Users browsing this forum: No registered users and 11 guests
There are no new unread posts for this topic. Wheel upgrade
montymoo
7
1060
Sat Jul 07, 2012 1:35 pm
montymoo View the latest post
There are no new unread posts for this topic. How to upgrade my caad10 5
loco2546
10
1491
Fri Jun 22, 2012 7:57 pm
loco2546 View the latest post
There are no new unread posts for this topic. upgrade old bike or buy new one
kamil1891
15
859
Mon Jan 07, 2013 8:45 pm
kamil1891 View the latest post
There are no new unread posts for this topic. What to upgrade this winter
russianbear
Wed Oct 10, 2012 9:24 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. Brain upgrade a RS SID WC XX
in MTB
Rogue
Sun Nov 18, 2012 9:03 am
XC-MTB View the latest post
It is currently Mon May 20, 2013 9:54 am
