Post new topic Reply to topic  [ 4 posts ]
 Post subject: Brake lever problem?
PostPosted: Sat Jan 17, 2004 3:20 pm
Hi. Anyone use left hydraulic disc brake lever on the right? will Upside- down lever will make any problems in braking? thanks.
 Post subject: that depends
PostPosted: Sat Jan 17, 2004 3:28 pm
It depends what brakes you're using. If you've got hopes with the 'mini' lever you can't turn it upside down. If you've got avid's you can. Not sure about other manufacturers though.
.....but it still has to work!
 Post subject:
PostPosted: Sat Jan 17, 2004 9:18 pm
All Hayes HFX models come with levers that can be mounted on both sides of the bar. Check out http://www.hayesdiscbrake.com
Cheers
Ivan
 Post subject:
PostPosted: Sun Jan 18, 2004 8:51 pm
Administrator
I think what Polaris is trying to say is, when you use levers with an oil expension part on the top of the lever (when it is normally mounted) you can't use that lever on the other end of the bar.
Follow me on twitter. I try to be interesting ;)
On Facebook!
Users browsing this forum: MartijnE, Yahoo [Bot] and 16 guests
There are no new unread posts for this topic. XTR M985 brake lever reversable?
in MTB
hjb1000
7
553
Wed Aug 22, 2012 3:34 pm
yourdaguy View the latest post
There are no new unread posts for this topic. Attachment(s) SRAM Red lever tune...
[ Go to page: 1 ... 7, 8, 9 ]
weeracerweenie
129
10072
Thu Dec 06, 2012 12:47 pm
weeracerweenie View the latest post
There are no new unread posts for this topic. Campag gear lever rattle
marathon50
Sun Aug 05, 2012 11:22 pm
ipenguinking View the latest post
There are no new unread posts for this topic. Record 11s sticky thumb lever?
wingguy
7
765
Tue Mar 26, 2013 10:04 pm
helios View the latest post
There are no new unread posts for this topic. Does my 10s Campy ergo lever need a rebuild?
JBV
7
567
Thu Jan 03, 2013 5:28 pm
It is currently Tue May 21, 2013 6:05 pm
