Post new topic Reply to topic  [ 3 posts ]
PostPosted: Sun Sep 16, 2012 3:34 pm
what are the alternatives to a Shimano remote lock out lever for Fox shocks? I would like to position the remote lever outboard of the brake lever - it is fitted in between the brake nad gear shifter clamps at present.
let's see if I can upload photo witthout explorer hanging up.
... or how easy is it to fit the fork leg lock out lever? Ok so it is not as convenient but I have a bike with this arrangmenet and get on swell with it. ..... and ofcourse that will be lighter.
PostPosted: Sun Sep 16, 2012 3:35 pm
photo added, success!!!
PostPosted: Fri Sep 28, 2012 7:05 pm
I spotted a Suntour (admittedly not as sexy as Shimano or Fox) lockout on ebay that has a band to attach to bars which means it should be able to fit under the shifter window and be fitted inboard of the shifter.
Received it in the post today and fitted it this evening - was expecting it to be cheap and nasty plastic affair but surprisingly it is alloy - wieghs 42g with the cable. It sits inboard of the shifter so now the shifter and brake levers are closer together - great :thumbup: , since previously the remote sitting in between them meant that the two were further apart, so much so that the 2 way shifter levers only worked in one direction due to the brake lever body getting in the way. :twisted:
The amount if throw for the two remotes is about the same - fitted the cable to the Fox forks and they lock out perfectly first time, no need for any fiddling.
So if you have Fox forks with remote lockout, Shimano shifters and Formula R1 brakes, you may wish to change the remote for a Suntour, see photo.
Users browsing this forum: Snabb and 9 guests
There are no new unread posts for this topic. Magura Electronic lockout
in MTB
ratherbeintobago
7
382
Mon May 27, 2013 8:36 pm
ratherbeintobago View the latest post
There are no new unread posts for this topic. Rockshox x-loc hydraulic lockout
in MTB
02GF74
7
591
Sun Dec 23, 2012 5:42 am
Rider10 View the latest post
There are no new unread posts for this topic. How do you remove the lockout on a DT Swiss XRC Race LTD?
in MTB
nrsnow
Mon Jun 10, 2013 5:56 am
skyfire1202 View the latest post
There are no new unread posts for this topic. New'12 Fox Fit 100mm Kashima Remote Lock 26 qr, $430
chrisMTB
Fri May 10, 2013 9:21 am
chrisMTB View the latest post
There are no new unread posts for this topic. TT Brake levers? -- Sram 990 vs 900
tdudzik
Fri Jun 14, 2013 11:35 pm
eigner View the latest post
It is currently Wed Jun 19, 2013 2:08 pm
