Post new topic Reply to topic  [ 15 posts ]
PostPosted: Sat Sep 15, 2012 5:40 pm
I love my Raceface Next SL seatpost. Only problem is it creaks like 200 year old stair case. I have taken it apart and cleaned, greased, or lubed everywhere I can and it persists. Looking around the Enve looks sweet for weight and setback, but I can't find any reliable reviews about the clamp head. I am leary of single bolt designs like that, so I am wondering if there is any feed back here about it.
PostPosted: Sat Sep 15, 2012 11:31 pm
I have had terrible luck with mine. It moves at the worst times, like at the beginning of every endurance race this year, seriously!
I have heard good things about Ritchey posts.
PostPosted: Sat Sep 15, 2012 11:36 pm
Location: somewere floating between here and the other side
not as light as the enve post is my moots post wich has served me very comfy the last 10 years...light compfy and durable !
PostPosted: Sun Sep 16, 2012 3:53 am
the enve posts are not my favorite (thomson), but i have had no problem with the head. one guy had saddle tilt slippage issues, turns out he greased the inner cylinder walls. after cleaning it all out, and for his case using some grip paste on the top cradle/top of cylinder wall area, there was no more slippage.
PostPosted: Sun Sep 16, 2012 7:25 am
thanks for the honest responses all!
PostPosted: Sun Sep 16, 2012 3:41 pm
On mtn bikes the clamp can move causing the saddle to tilt. Had to tighten the bolt tighter than the torque spec, Enve said this was ok to do. Also added a little carbon paste for extra friction in the clamp head. Try the Niner RDO post if you want a more secure carbon post that will ride nice (more flexible carbon layup), not the lightest, but works good.
PostPosted: Sun Sep 16, 2012 4:22 pm
Just saw on the Enve website that they call for 12nm torque on that bolt now. That is crazy tight. I am gathering from sources now that carbon paste helps the solution a lot. I saw the Niner post, but unfortunately, no offset.
PostPosted: Sun Sep 16, 2012 7:47 pm
For what ENVE charges for that post, you would think this thing would work flawlessly!
PostPosted: Sun Sep 16, 2012 9:06 pm
For what they charge I would expect something much lighter as well..
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Sun Sep 16, 2012 9:43 pm
The trick is to apply a bit of grease on the alu parts, where they touch each other. IOW on top of the wedges.
PostPosted: Mon Sep 17, 2012 7:00 am
How much setback do you need? Depending on your saddle rails you can get quite a bit out of the Syntace posts despite not having an offset head.
PostPosted: Mon Sep 17, 2012 7:38 pm
Current is 1.5cm, but the 2.5cm will be ideal.
PostPosted: Mon Sep 17, 2012 7:52 pm
I've been pretty happy with how my superlogic seatpost works: I'm 155lbs, do aggressive XC on a hardtail. I would not go with the enve for its cost, weight, and purported slippage issues.
About clearing up seatpost creaks: I have very good luck with applying friction paste to everything: seatpost shaft, saddle rails, clamping surfaces, where the bolt rests, etc. Since the Next uses a bonded aluminum head, this part could be flexing and causing the creak. I try and stay with posts that have no bonded parts: I.e. Thompson, Ritchey's higher end stuff, Specialized's posts, others.
PostPosted: Mon Sep 17, 2012 8:49 pm
If you want a post that holds your saddle in a death grip, go with a Thompson :thumbup:
viewtopic.php?f=10&t=81983
PostPosted: Mon Sep 17, 2012 9:22 pm
The creak is coming from the pivots of the support arms. You can't disassemble the post t get grease in there, and any oil you put in solves it for about half a ride. Great post for adjustment, but poor design for noise. I know three different guys who ride this post, or the aluminum post version of it. They all creak in the same places.
Users browsing this forum: No registered users and 15 guests
There are no new unread posts for this topic. Enve 110mm stem & Enve 27.2mm layback post - both BNIB
BikeTart
Fri Apr 05, 2013 9:16 am
BikeTart View the latest post
There are no new unread posts for this topic. Enve 110mm stem & Enve 27.2mm layback post - new, boxed
BikeTart
Mon Apr 15, 2013 1:32 pm
There are no new unread posts for this topic. Light reliable tubes?
in MTB
nrsnow
9
816
Fri Jul 20, 2012 2:51 am
nrsnow View the latest post
There are no new unread posts for this topic. Light, strong, reliable and inexpensive skewer
in MTB
lowpsihighspeed
18
1202
Fri Apr 26, 2013 12:37 am
thewatchtech View the latest post
There are no new unread posts for this topic. Light, reliable semi-integrated headset?
in MTB
DanW
Tue Mar 26, 2013 2:41 pm
yourdaguy View the latest post
It is currently Thu May 23, 2013 4:42 am
