Post new topic Reply to topic  [ 6 posts ]
PostPosted: Fri Sep 07, 2012 7:43 pm
hmmmm, I don't seem to be getting good indexing with a SRAM rear mech and cassette - if I adjust so the small cogs shift nicely, then there is not quite enough cablr for the large cogs; and vice versa.
I have used then on a Shimano rear mech and did not have this issue, but then don't Shimano rear mechs pull less cable?
looks like i will have to refit steel cable and use prowercordz just on the front :(
PostPosted: Mon Sep 10, 2012 10:24 am
Stupid question, but you are using a SRAM shifter aren't you, and it's all setup for the same number of gears? I can't see how a cable could affect indexing unless it's really gritty and siexed up?
PostPosted: Mon Sep 10, 2012 3:50 pm
I'm running powercordz on the rear myself. No problems what so ever. Either the adjustments are off or you are not using a Sram shifter.
WTB: MTB hubs, 29'er carbon rims
My 7.3kg/6.4 kg 29'er project buildthread!
My Bianchi Oltre XR
PostPosted: Mon Sep 10, 2012 8:45 pm
I replaced the steel cable that was shifting perfectly by the powercordz - system is SRAM X0 shifter and X0 mech. The shifter housing is all new, mini ilink.
I gave up in the end and fitted back the steel cable. :twisted: I have response from powercordz that seem to imply there can be issues with SRAM (I have identical set up on Shimano that works fine).
PostPosted: Mon Sep 17, 2012 10:16 pm
Next time I recommend reading the compatibility page on Powercordz web first (http://www.powercordz.com/compatibility" onclick="window.open(this.href);return false;) :smartass:
Mini i-Link Beaded Housing
While Power Cordz™ are great with Alligator’s regular i-Link beaded housing, the inner diameter of the mini i-Link is too small to be compatible. Some riders have used Mini i-Link beaded housing without inner liners and found a good fit. However, without an appropriate inner liner, there is a significant risk of friction between the Cordz jacket and rough inner surface of the Mini i-Link housing.
MTB - Van Nicholas Zion
Road - Van Nicholas Euros
PostPosted: Tue Sep 18, 2012 9:24 am
Ok, I didn't spot that but it does not apply to me. :noidea:
I am using them with a liner - I have the exact same set up except with XT shifter and XTR rear mech on another bike and no shifting issues.
If I get round to it, I will try to compare the mini i-link liner to shimano shifter cable liner to see if there is a difference.
Not convinced at this moment that it is a liner issue though.
Users browsing this forum: No registered users and 9 guests
There are no new unread posts for this topic. Attachment(s) SRAM Apex Rear Mech/Derailleur
Tug Boat
Sat Mar 02, 2013 5:30 pm
Tug Boat View the latest post
There are no new unread posts for this topic. 1st gen sram red and powercordz
styrrell
Mon Mar 25, 2013 8:08 pm
sungod View the latest post
There are no new unread posts for this topic. Powercordz with Sram Force
Jwhelan939
Mon Nov 19, 2012 4:47 am
theremery View the latest post
There are no new unread posts for this topic. 7900 dura ace rear mech
mec287
Fri Jan 18, 2013 3:03 pm
eric View the latest post
There are no new unread posts for this topic. Super Record 11 Rear Mech Failure - any others out there ?
lycralout
21
1512
Mon Sep 24, 2012 5:11 pm
Powerful Pete View the latest post
It is currently Thu May 23, 2013 9:51 am
SRAM - bike parts & bike components from SRAM at cheap prices
