Post new topic Reply to topic  [ 8 posts ]
PostPosted: Fri Sep 07, 2012 3:02 pm
Hello guys. I am a first time poster, but long time reader on this great forum
I am in the process of making a spreadsheet for lightening my bike and got stuck at the seatpost clamp. I've measured the outer diameter on my Trek frame to 36,2mm, and that's where I got stuck. The one I have weigh 55g and I can't seem to find a light replacement other than "Hope" which I'm not really into =/ Do any of you guys know of a light clamp this size?
Thanks in advance, Mikkel.
Trek 6000 and Cannondale R500 - To Be WeightWheenied...
PostPosted: Fri Sep 07, 2012 6:11 pm
I'm not familier with that tube width, the ones I've suggested below may work but you should probably check first. I'm sure someone on here will have the same frame, you should try searching in the forum search facility.
If you're looking to lighten your bike the you should definitely use xcracer.com. Amazing service and a great site in general too.
Try these:
http://www.xcracer.com/shop/viewproduct ... ductid=110
http://www.xcracer.com/shop/viewproduct ... ductid=268
Bike: 2012 Boardman HT Pro MTB - 21.949lbs / 9.956kg (for now...)
PostPosted: Fri Sep 07, 2012 8:02 pm
Thanks for your reply chucklight. I also thought it was kinda weird when I measured it. But it's an older Trek 6000 frame, and my guess is that they used some thicker tubing as it was one of their cheaper models.
Anyone think a 34,9mm clamp would be able to stretch a little to fit approx 36mm ?
PostPosted: Sat Sep 08, 2012 7:09 am
What you need is a custom clamp. Tune, mcfk, Lire Carbon Smud etc.
It will get expensive, so might want to think if it is worth to invest in your Trek
Chris.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Sat Sep 08, 2012 12:40 pm
Smud carbon has the best build quality/weight for its price.
Edit: if you go for the lightest option it might save you +- 50 gram.
PostPosted: Sun Sep 09, 2012 9:13 am
Awesome Tom-s, I can see they got it in a size 36mm and it's incredibly light. Will defo go for that one at a very reasonable price too.. Any comments on how well it holds the seatpost for mtb-xc-riding?
PostPosted: Sun Sep 09, 2012 1:19 pm
I recall those treks using a "35.9mm" clamp, essentially 36mm.
PostPosted: Sun Sep 09, 2012 2:06 pm
@ thisisatest
Yea, that's approximately the size I've measured with a pair of calipers. I guess it varies a bit on lower end bikes..
Users browsing this forum: No registered users and 12 guests
There are no new unread posts for this topic. Light Weight Seatpost Shim and Seatpost Clamp ?
in MTB
Scott35
Thu Apr 25, 2013 5:16 am
gifted child View the latest post
There are no new unread posts for this topic. overtighened seatpost clamp. damaged seatpost.
odin99
9
695
Tue May 07, 2013 8:09 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. 30.9 seatpost clamp
SSB
Wed Jul 04, 2012 1:43 am
SSB View the latest post
There are no new unread posts for this topic. Litespeed C1 Seatpost Clamp
Renegaderider
Sat Jul 21, 2012 3:12 pm
2011 View the latest post
There are no new unread posts for this topic. MCFK seatpost clamp
NiFTY
Sat Aug 18, 2012 12:00 pm
Juanmoretime View the latest post
It is currently Wed May 22, 2013 6:28 pm
